3
Call Recording Function should be brought back on The 3/3T
  1. pranitpanse
    Eclair Sep 10, 2018
    pranitpanse , Sep 10, 2018 :
    Hey folks,
    OnePlus had introduced the call recording feature In the OP3T but they removed it in the later update!. It was a very helpful feature and I think we should get that feature back.
    it was very good compared to other 3rd party apps
    support this thread so that it reaches the OnePlus team!
  2. strafer
    Lollipop Sep 10, 2018
    strafer , Sep 10, 2018 :
    If you would have done a little search you would know that function is still there but blocked in countries where it is not allowed by law - like in India.
  3. santhosh311983
    Honeycomb Sep 10, 2018
    santhosh311983 , Sep 10, 2018 :
    I reside in India ..and still using call recorder features ..but after the update you need to enable the feature ..below are the settings ..
    go to phone default dialler ..and on the top right you will see 3 dotted lines ..click on it and go to SETTINGS --> CALL RECORDER ..and enable it ..simple ..
    dineshsp04 and strafer like this.
  4. ghostofcain
    Marshmallow Sep 10, 2018
    ghostofcain , Sep 10, 2018 :
    Google have removed the call recording API, in Oreo, in android P they are actively blocking call recording , I'm afraid you are behind the times.
    Eustacio Sealy likes this.
  5. Amitp1998
    Amitp1998 , Sep 10, 2018 :
    I think u have direct connection from Google ........idiotic talks
    pranitpanse likes this.
  6. MasterSwami
    Ice Cream Sandwich Sep 10, 2018
    MasterSwami , Sep 10, 2018 :
    I don't what you guys are talking about.
    i use the call record feature on op 6 running Open Beta 2 Android Pie.
  7. tejaslrajput
    Gingerbread Sep 10, 2018
    tejaslrajput , Sep 10, 2018 :
    i am in India, i still have call recorder in my phone, I am on 5.0.5
    drrahul likes this.
  8. ghostofcain
  9. F_ER_Aadil_Chogle_YXRG
    Froyo Sep 10, 2018
    F_ER_Aadil_Chogle_YXRG , Sep 10, 2018 :
    im from india n call recording just works fine
  10. dxpxxx
    Cupcake Sep 10, 2018
    dxpxxx , Sep 10, 2018 :
    I am also from India and using the OnePlus 3 with Android 8.0 and oxygen is v 5.0.5 ,call recorder option is not available for me also after the recent updates
    Please can you enable this for the next release , it is very good feature.
  11. Eustacio Sealy
    Eustacio Sealy , Sep 10, 2018 :
    Well if you are not running the oficial stable version many things that should work don't and some that should not do
  12. Its.Leandroo
    The Lab - OnePlus 6 Reviewer Sep 10, 2018
    Its.Leandroo , Sep 10, 2018 :
    Just curious, but isn't recording calls very sketchy.
    Like, if you are a company that deal with important financial phone calls, sure.
    But do you really have to record everything what friends and family say? Or do I miss something here.
  13. Android450
    Android450 , Sep 10, 2018 :
    They say it's to combat telemarketing but I think the block button works just as well :D
    Worst case scenario the ones asking for it are those same telemarketers who need a useful tool for their scams :rolleyes:
    ghostofcain likes this.
  14. drishya.maity
    Eclair Sep 10, 2018
    drishya.maity , Sep 10, 2018 :
    It's actually a very useful tool for writers and journalists who interview subjects over telephone. Personally, I use it a lot when I'm talking to someone about a story, and it comes in handy because I can listen to the recordings to make notes at my convenience.
  15. rishugupta09
    Froyo Sep 11, 2018
    rishugupta09 , Sep 11, 2018 :
    same for me
  16. doctorkimble
    Froyo Sep 11, 2018
    doctorkimble , Sep 11, 2018 :
    In germany call recording is NOT forbidden by law (you'll need the consent, though) and I can only enable call recording temporarily using the joneplustools. But after a while, call recording gets disabled again. This sucks.
  17. F_Amit_Kumar_Bidaser_NXR
    Gingerbread Sep 26, 2018
    F_Amit_Kumar_Bidaser_NXR , Sep 26, 2018 :
    I am in India nad have just updated my OP 3t to OOS 5.0.5 and now the call recording option is gone. No option is there to enable it through Dallier settings as well.
