9
Call Recording issue in Android 10 via OnePlus 5T
  1. foxglove.bd
    Cupcake Jun 1, 2020
    foxglove.bd , via OnePlus 5T , Jun 1, 2020 :
    Thanks OP for adding the Call recording option in OP5t. I have noticed a problem while playing the recorded call. The recorded call sounds like loosing tempo. It sounds like slurred or sluggish. Call recorder has two options for recording format. wav or acc. But in both formats, the problem remains the same. Did anyone notice this problem?
    Thank You.
  2. fahadka
    Cupcake Jun 2, 2020
    pawan.pendkar likes this.
  3. shr3yan5
    Cupcake Jun 2, 2020
    shr3yan5 , Jun 2, 2020 :
    Same issue here in stable Oxygen OS 10 !!
    Can anyone help how to fix this, Call recording is very essential for me!
  4. pawan.pendkar
    Cupcake Jun 2, 2020
    pawan.pendkar , Jun 2, 2020 :
    Hi guys,
    Hope you can understand the importance of call recording function. Please suggest at least a temporary solution on this.
  5. the_o2
    User of the Year 2018 Jun 2, 2020
    the_o2 , Jun 2, 2020 :
    report this bug here
    https://forums.oneplus.com/feedback
  6. vikhanna
    Cupcake Jun 5, 2020
  7. E1545988921100
    Cupcake Jun 6, 2020
  8. alziyadh
    Cupcake Jun 16, 2020
    alziyadh , Jun 16, 2020 :
    I'm facing the same issue.
    Does anyone know how to fix this issue please let us know
  9. ariel.levin
    Donut Jun 16, 2020
  10. BN Yogesh
    Donut Jun 22, 2020
    BN Yogesh , via OnePlus 5T , Jun 22, 2020 :
    Hi Guys,
    facing same problem after the update, manul voice recorder is perfect but the call recording is has some malfunction and it won't even working even if change recording format.
    I tried sending the fike to other phone, but there is not use it is same voice.
    OnePlus team please fix the as I use this every often.
  11. G_Rafique_Shaikh_qswc
    Cupcake Jun 22, 2020
    G_Rafique_Shaikh_qswc , Jun 22, 2020 :
    I am facing the same issue after OS 10 upgrade, I have uninstalled the recording app and install again, but the issue is not fixed but sometimes call record perfectly working sometimes not. I think it is s bugs and Oneplus team can be solved after releasing the new update.
    f
