4
Call recording not proper via OnePlus 5T
  1. Dpak5
    Eclair Aug 1, 2020
    Dpak5 , via OnePlus 5T , Aug 1, 2020 :
    After updating oneplus 5t to android 10 the call recording is not clearly audible it sounds like robots and at very slow speed. Kindly help.
  2. Ashishgupta8877
    Donut Aug 1, 2020
  3. F1548498921948
    Cupcake Aug 1, 2020
    F1548498921948 , Aug 1, 2020 :
    same here too,
    on my OnePlus 5T with oxygenOS 10 I am facing bug issues while recording the phone calls. it's not recording properly
    might not be relevant but please you insight is appreciated.
    AjitKulkarni and mrugesh0719 like this.
  4. Dpak5
    Eclair Aug 1, 2020
    Why no1 from oneplus support in conmunity is responding. If we post a duplicate thread we get a warning just in few hours of posting. Thn why such genuine issues are not addressed.
    mrugesh0719 likes this.
  5. AjitKulkarni
    Cupcake Oct 30, 2020
  6. Dpak5
    Eclair Oct 30, 2020
    Dpak5 , via OnePlus 5T , Oct 30, 2020 :
    To fix this problem you have to turn off your google assistant completely. Then it works fine. Either you can use google assistant or call recording.
  7. gohelbhavik
    Donut Oct 30, 2020
  8. AjitKulkarni
    AjitKulkarni , Oct 30, 2020 :
    Dpak5
    To fix this problem you have to turn off your google assistant completely. Then it works fine. Either you can use google assistant or call recording.​
    there is issue in call recording only, not in recorder app, and this problem occurs after update to Android 10, so please give solution
