Call Recording Storage via OnePlus 7T
  1. ravimishra28
    Donut May 11, 2021
    ravimishra28 , via OnePlus 7T , May 11, 2021 :
    Where are call recordings stored? They show in the call logs but cannot locate them on phone memory. I am using OP 7T OOS 11.0.0.2 . Previously they were stored in a folder Record but after the new update no such folder is created. Kindly reply.
  2. Aaron2017
    KitKat May 11, 2021
    Best Answer
    Aaron2017 , May 11, 2021 :
    They should be here now
    Android/Data/com.oneplus.communication.data/files/Record/PhoneRecord
    the_o2, Suv94., McJader and 5 others like this.
  3. ravimishra28
    Donut May 11, 2021
    Aaron2017 likes this.
  4. G1607746807583
    Cupcake May 12, 2021
    G1607746807583 , May 12, 2021 :
    Hi,
    I am using OnePlus Nord.
    This new path doesn't work for me. It says "No Files".
    Even the Record folder says "No Files".
    What could be the issue here?
  5. pablofg1978
    Head Moderator Head Moderator May 12, 2021
    KluGe likes this.
  6. G1607746807583
    G1607746807583 , via OnePlus Nord , May 12, 2021 :
    Thanks for sharing the link.
    It tells me where I can access the recordings from.
    It doesn't tell me where they are stored.
    I want to know the location of the storage folder so I can copy them and save it on a private cloud server.
    Due to the nature of my work, I need to record certain calls and make it available whenever asked for.
    Any link that can help me locate the folder?
  7. pablofg1978
    pablofg1978 , May 12, 2021 :
    I suggest you to read and use the thread that I Linked to you to find your answer, this thread is for a diferent device
  8. G1607746807583
    pablofg1978 likes this.
