call recording
  1. Arif.2772
    Cupcake Aug 1, 2019
    Arif.2772 , Aug 1, 2019 :
    please do something about the call recording. the call recording should be easily accessible through recording app.
  2. mateusz91
    Honeycomb Aug 1, 2019
  3. akks
    KitKat Aug 1, 2019
    akks , Aug 1, 2019 :
    That's isn't a good solution. I think what he meant was an easy accessibility of the recorded contents in the stock call recorder.
    That's needed indeed. Easy accessibility of the recorded conversations. Right now it's quite tedious to get the recorded conversations.
    This should be posted in the feedback section, not here.
  4. Gupts007
    Froyo Aug 2, 2019
    Gupts007 , Aug 2, 2019 :
    Every since Android Pie came out Google blocked these apps from recording calls. So they don't work anymore. What works is the pathetic inbuilt Google recording system that doesn't let you exclude certain select numbers.... Something so elementary and they don't let you do that
