Call Recording via OnePlus 3T
  1. AndrewC
    Cupcake Dec 7, 2019
    AndrewC , via OnePlus 3T , Dec 7, 2019 :
    Hi, current 3T is due to be upgraded, looking at the 7T or Pro device but an important feature is being able to record calls both sides which used to work OK with ACR recorder with my licence but stopped working after the last update from Oneplus.
    Does anyone know if the 7 series devices allow call recording without having to root the device which I don't want to do?
    My wife changed her 3T for the Honor 20 which has its own call recorder and works great, I may have to consider changing brands but having started with the Oneplus X moving on to the 3T I am reluctant to change.
    Any suggestions or advice welcome, thank you 😀
  2. Titaniumlad
    Eclair Dec 7, 2019
    Montucky likes this.
  3. djtiestoja
    Gingerbread Dec 7, 2019
    Montucky and Andrewcrezi like this.
  4. विश्व_भनेको_मै_हो , Dec 8, 2019 :
    adb thru computer doesn't void warranty, does it?
    Andrewcrezi likes this.
  5. Maldor96
    Cupcake Dec 8, 2019
    Maldor96 , Dec 8, 2019 :
    No it doesn't, I've been able to use my phones with no issue and adb. Just be aware of how the commands work and do your research and you should be fine.
  6. CaptJackSparr0w
    Gingerbread Dec 8, 2019
    CaptJackSparr0w , via OnePlus 7T , Dec 8, 2019 :
    Oneplus 7T has own call recorder and doesn't need root or abd commands. I'm using recorder from day one on my phone and with every update it is still there.
  7. Q1575774476259
    Cupcake Dec 8, 2019
    Q1575774476259 , Dec 8, 2019 :
    call recoding & music both are saved equelly@ call recoding erase file pursanly select are one bye one
  8. AndrewC
    Cupcake Dec 8, 2019
    AndrewC , via OnePlus 3T , Dec 8, 2019 :
    What country are you in? From what I have read it depends on the country sim card if its disabled. Used to work on 3T until last android /oneplus updated.
  9. विश्व_भनेको_मै_हो , Dec 8, 2019 :
    indian model has it.. mine is chinese so
  10. CaptJackSparr0w
    I'm from India and it works like charm... [e]1f609[/e]
  11. AndrewC
    Cupcake Dec 8, 2019
    Uk versions are blocked since the last Google android update.
    gaurav27jul likes this.
  12. AndrewC
    Cupcake Dec 8, 2019
    Will give that a go with my current 3T see if it works thanks
  13. CaptJackSparr0w
  14. AndrewC
    Cupcake Dec 8, 2019
    It's the sim card that you have in that makes it disabled due to the privacy laws. Funny though my wife's Honor 20 call recorder works.
  15. AndrewC
    Cupcake Dec 9, 2019
    AndrewC , via OnePlus 3T , Dec 9, 2019 :
    Actually working using you fix great stuff and thank you so much for taking the time to reply to my post. Only issue I see, but I can live with it, it puts the record in the music files, I can't see any option to change default save folder. Thanks again [e]1f601[/e] much appreciated [e]1f60a[/e]
    djtiestoja likes this.
  16. djtiestoja
    Gingerbread Dec 9, 2019
    djtiestoja , via OnePlus 7T Glacier Blue , Dec 9, 2019 :
    No problem mate glad to help you. I needed also badly so why not to help.
  17. ironhorse99
    Cupcake Mar 10, 2020
    ironhorse99 , Mar 10, 2020 :
    can you tell me exactly where this is located. I just spent considerable time & can't find it.
  18. ironhorse99
    Cupcake Apr 18, 2020
    ironhorse99 , Apr 18, 2020 :
    Where is this function located. I live in the US & the state I live in only restriction is 1 party must know of recording. I have no option I can find.
  19. CaptJackSparr0w
    Gingerbread Apr 18, 2020
    CaptJackSparr0w , via OnePlus 7T , Apr 18, 2020 :
    Go to phone dialer app> click on 3 dot on the top right corner > then click on settings > first option is call recording under calls.
  20. ironhorse99
    That option is not there.
