Call recordings disappeared after android 11 update
  1. H1561708316391
    Cupcake Jun 23, 2021
  2. Q1626399919094
    Cupcake Jul 16, 2021
    Q1626399919094 , Jul 16, 2021 :
  3. Q1626399919094
    Hi could you find your earlier files. If yes explain the process. The newer recorded files are present on the phone int he android folder which si fine. Need to know about the older ones. They are precious to me.
  4. Y1562366964586
    Y1562366964586 , via OnePlus 7 , Jul 16, 2021 :
    Don't go thru file manager, to thru Files, or any other file explorer app from play Store after giving permission. Then go to Android_data_com.oneplus.communications
    There you'll find previous recordings
  5. geekyanky
    Cupcake Jul 20, 2021
    geekyanky , Jul 20, 2021 :
    Hello fellow Oneplus 7 users. Ik I might be somewhat late to post this. After going through the replies and some practical I have finally found the solution. So basically, there is no bug in the Oneplus default file manager, it's just that due to Android 11 policies, we are unable to see the recordings in file manager even though they exist. So, now to recover these recordings or backup or copy them, we need to use a file manager that will have the most basic sense to let us know that it is unable to access: Android>data>com.oneplus.communications. For this we will use the mi file manager.
    1. Try to access the said location through it and it will ask for permission, but after that it would not be able to access it directly and the folder would be opened through the google "files" up.
    2. Now once you open this folder, just open every folder that you will encounter and finally you will have a list of all your call recordings that you were able to see in call app but not in file manager.
    3. Now, you can copy or cut and paste it wherever you want through that files app itself, preferably to a location where the normal file manager can have access. That's it.
    Let me know if you have any queries.
  6. khwaja_shaikh
    Cupcake Jul 24, 2021
    khwaja_shaikh , via OnePlus 7 , Jul 24, 2021 :
    The new path for call recording is
    Android/Data/com.oneplus.communication.data/files/Record/PhoneRecord
    To me its more organized then previous becouse no more manually search directly can access from dialer app
  7. Naruto1613
    Cupcake Jul 26, 2021
    Naruto1613 , Jul 26, 2021 :
    I have tried everything suggested above. Cache clear, App update, Enabling Show Hidden Files. But nothing works. Even there is nothing to be seen here in the mentioned location of Android/data/
    It's completely blank. I think there is some major changes in Android 11. But I need all my recordings transferred to my laptop. If anyone has found any work around to this, pls pls pls share. I am in dire need.
  8. McJader
    Marshmallow Jul 26, 2021
    McJader , Jul 26, 2021 :
    Use Total Commander
    Naruto1613 likes this.
  9. Naruto1613
    Cupcake Jul 28, 2021
    Naruto1613 , Jul 28, 2021 :
    Hey Man!
    Thank you very much for sharing that, that worked perfectly fine. Just the thing I needed. "Total Commander".
    McJader likes this.
  10. nerlim
    Cupcake Jul 29, 2021
    nerlim , Jul 29, 2021 :
    Hi, is there a way to activate calls recordings on android 11 ops 7? Thank you
  11. N1625367144895
    Cupcake Sep 5, 2021
    N1625367144895 , Sep 5, 2021 :
    Yes I face the same ..please those are my imp recordings ...please help to find
  12. N1625367144895
    Cupcake Sep 5, 2021
    Please help me I am facing similar issue
  13. McJader
    Marshmallow Sep 5, 2021
    McJader , Sep 5, 2021 :
    Read this:
    Artemus and ShreyasPatil_ like this.
  14. H1609409657977
    Cupcake Sep 8, 2021
    H1609409657977 , Sep 8, 2021 :
    Same issue with me bro. But tried what u have done but still it's empty. Can u draft the process how u got it back
  15. Y1562366964586
    Cupcake Sep 8, 2021
    Y1562366964586 , via OnePlus 7 , Sep 8, 2021 :
    @ShreyasPatil_ said
    The location has been moved to
    Also quick way to find recordings is
    Open dialer app -- call log -- tap on 3 dots of any call log -- call recording -- the file will be visible -- again click on 3 dots and tap on view in file manager.
    Shivohamm likes this.
  16. Shivohamm
    Cupcake Sep 14, 2021
    Shivohamm , Sep 14, 2021 :
    How to access this location : Android/Data/com.oneplus.communication.data/files/Record/PhoneRecord
  17. Shivohamm
    Please help!
  18. PraveenSulibhavi
    Cupcake Sep 24, 2021
    PraveenSulibhavi , via OnePlus 6T , Sep 24, 2021 :
    Still facing the same issue
    Tried above all steps and even total commander bit still issue remains the same.
    Guys please help.. I hv very important recordings 🙏🏽
    #38
  19. rathodhiren081
    Cupcake Oct 23, 2021
    rathodhiren081 , Oct 23, 2021 :
    Found the solution
    Call settings --> call recording --> view all recordings
    #39
  20. rathodhiren081
    #40
