Call volume on capsule suddenly very low
  1. frankge973
    Cupcake Jul 31, 2018
    frankge973 , Jul 31, 2018 :
    from one day to another and without installing any OS update, the call volume on capsule become very low. I tried to adjust with volume keys on left side but it is already to maximum.
    any suggestion for solving this annoiyng problem ?
    Thanks to all
  2. Gingabex
    Gingabex , Jul 31, 2018 :
    Sorry I can't help, but I have exactly the same problem. I have tried clearing cache and a factory reset, but this didn't work. I will be watching this thread closely...
  3. frankge973
    it happened another time and I don't remember in which way ( or by itself) the problem disappeared
  4. frankge973
    Cupcake Aug 1, 2018
  5. frankge973
    Cupcake Aug 2, 2018
    frankge973 , Aug 2, 2018 :
    someone had found a solution ?
    technical support suggests me to hard reset the phone
    boh ..... I have some doubts
  6. Gingabex
    Cupcake Aug 2, 2018
  7. frankge973
    Cupcake Aug 2, 2018
  8. frankge973
    Cupcake Aug 2, 2018
  9. Riddhesh Khatu
    Gingerbread Aug 5, 2018
    Riddhesh Khatu , Aug 5, 2018 :
    i was facing the same issue
    recently i was facing some other issue with my device so i re-flashed the rom
    also i had cleaned the earpiece with a soft brush oriented in a Zig-Zag manner(i had done this earlier too)
    now the volume is decent enough to hear outdoors
    i really don't know what exactly made it better but you can try any of the methods and see if it works
  10. frankge973
    Cupcake Aug 5, 2018
    frankge973 , Aug 5, 2018 :
    no no no . hear me ... the problem is dust on grid . please use some adhesive like Patafix . use a bit and press firmly on grid. then remove it .... repeat several time
