Caller ID delay via OnePlus 7
  1. navakanth_b
    Cupcake Oct 11, 2021
    navakanth_b , via OnePlus 7 , Oct 11, 2021 :
    I am facing caller ID delay when receiving calls .
    I'm facing this issue since the oxygen os 11 update.
    Please suggest solution to this problem.
    Harsh_Vaishnav likes this.
  2. Dresa91
    User of the Year 2016; Most Active User 2020 Community Expert Oct 11, 2021
    Dresa91 , Oct 11, 2021 :
    hey,
    can you please clear cache and storage of the phone app and then clear cache in recovery?
  3. navakanth_b
    Cupcake Oct 13, 2021
    navakanth_b , via OnePlus 7 , Oct 13, 2021 :
    Yes, did that still not working
  4. Dresa91
    User of the Year 2016; Most Active User 2020 Community Expert Oct 13, 2021
    Dresa91 , Oct 13, 2021 :
    did you enable battery optimization for the dialer app? if yes, please disable it.
  5. navakanth_b
  6. Dresa91
    Okay.
    And did you perform a factory reset after the major update from A10 to A11?
  7. Harsh_Vaishnav
  8. navakanth_b
    Cupcake Oct 17, 2021
  9. Dresa91
    User of the Year 2016; Most Active User 2020 Community Expert Oct 17, 2021
    Dresa91 , Oct 17, 2021 :
    Can you please do it?
    This helped a lot of users with issues after the major update
  10. navakanth_b
    Cupcake Oct 18, 2021
    navakanth_b , via OnePlus 7 , Oct 18, 2021 :
    Done with reset but problem not solved
  11. Dresa91
    User of the Year 2016; Most Active User 2020 Community Expert Oct 18, 2021
    Dresa91 , Oct 18, 2021 :
    can you please check the battery settings for the phone app again
  12. navakanth_b
    Cupcake Oct 21, 2021
  13. Dresa91
    User of the Year 2016; Most Active User 2020 Community Expert Oct 21, 2021
    Dresa91 , Oct 21, 2021 :
    And all notorious are enabled?
    And you cleared all the caches?
  14. navakanth_b
    Cupcake Oct 23, 2021
  15. Dresa91
    User of the Year 2016; Most Active User 2020 Community Expert Oct 23, 2021
    Artemus likes this.
