4
calling issue
  1. Bharath Sid
    Donut Jan 12, 2018
    Bharath Sid , Jan 12, 2018 :
    After OxygenOS 5.0 update I am experiencing a wierd issue.
    While calling any number, I have to wait for 20-30 seconds before it connects...!
    It has not been fixed even after 5.0.1.
    Please help
  2. mr_priyanshu
    Jelly Bean Jan 12, 2018
    mr_priyanshu , Jan 12, 2018 :
    Force stop or uninstall MyJio app
    Bharath Sid likes this.
  3. Bharath Sid
    Donut Jan 12, 2018
  4. sreenathkaredath
    Donut Jan 12, 2018
    sreenathkaredath , Jan 12, 2018 :
    Following issues came after upgrading to 5.0.1
    1. Takes 10 - 20seconds to make a call after i click on the call button. And sometimes it crashes.
    This is the worst bug i ever had in this phone and i request you to fix this bug ASAP. The primary need of the phone (making calls) doesn't works properly, then whats the use of it.
    2. Battery draining . Only getting SOT of 3hrs or less(uses 4g volte and occasional wifi).
    3. Whatsapp and other downloaded Videos viewed from gallery gets very laggy.
    4. Apps crashes frequently.
    5. Finger print vibration gets lagged.
    I hope you consider the problems that im facing recently. call and battery issues are something that you should give high priority.
    Thanks in advance
    Peace [e]270c[/e][e]1f60a[/e]
  5. C1511758639292
    Donut Jan 12, 2018
  6. deepsP
    Cupcake Jan 12, 2018
  7. hastimal
    hastimal , Jan 12, 2018 :
    Facing all the above posted by sreenath. And also the phone freezes often. Which is weird because new updates are supposed to make the phone better and complicate it.
    I know your team will do the needful. Thank you
  8. Kaizaadbanaji
    Froyo Jan 12, 2018
  9. Kaizaadbanaji
    Froyo Jan 12, 2018
  10. sibarampati
    Eclair Jan 12, 2018
    sibarampati , Jan 12, 2018 :
    kill all apps from your multitasking button then go to setting~apps~application list~ in left hand side corner you found a 3 doted menu go there and reset app preference. after that just restart your phone. it really work for me. I hope it works for you.
  11. Lokesh l
    Lokesh l , Jan 12, 2018 :
    the same here what to do???
  12. C1511758639292
    Donut Jan 13, 2018
    C1511758639292 , Jan 13, 2018 :
    done this process
    no improvement...
  13. sibarampati
    Eclair Jan 13, 2018
    sibarampati , Jan 13, 2018 :
    then do this process
    Step 1: Power OFF your OnePlus device.
    Step 2: Press and hold Volume down and power key simultaneously until the device vibrates in Recovery menu
    Step 3: Select your preferred language as English
    Step 4: Select Wipe data and cache
    Step 5: Now select Wipe cache
    Step 6: Select Yes to continue the process
    Step 7: Select Reboot
    C1511758639292 likes this.
  14. C1511758639292
    Donut Jan 13, 2018
    this process effects on personal data in phone memory.
  15. sibarampati
    Eclair Jan 13, 2018
    no this process didn't effect in your phone data it's just delete some temporary files.
  16. Tricolour
    Eclair Jan 13, 2018
    Tricolour , Jan 13, 2018 :
    Only factory reset can resolve all the problems. Mee too was facing dialing delay, notification dot bug, parallel space problem, secure box related problem etc...
  17. sreenathkaredath
    Donut Jan 13, 2018
  18. jasonarima
    Gingerbread Jan 13, 2018
  19. monika_bhagat22
    Cupcake Jan 13, 2018
  20. G_Nitin_Chhajed_CJuX
