Calls triggered automatically with bluetooth connection Parrot CK3100 issue via OnePlus Community App
  1. saadhamani , via OnePlus Community App , Jun 2, 2020 :
    Hello,
    I would like to report a bluetooth connection bug between my Oneplus Pro 7 5G and my bluetooth car kit "Parrot CK3100".
    Few seconds after the successful bluetooth connection, calls are automatically triggered repeatedly to my last called number without my intervention. The only way to stop this is to disconnect the bluetooth connection.
    Could you please enlighten me on this issue and suggest me a quickest solution please?
    Regards
  2. Artemus.
    Nougat Jun 2, 2020
    Artemus. , Jun 2, 2020 :
    That seems like a malfunction on Parrot's part. Have you contacted them about it?
  3. saadhamani , via OnePlus Community App , Jun 7, 2020 :
    I've tested the Parrot with another Oneplus 6 phone and Samsung phone, there's no problem.
  4. Artemus.
    Nougat Jun 7, 2020
    Artemus. , Jun 7, 2020 :
    Well, did you contact them though?
  5. saadhamani , via OnePlus Community App , Jun 8, 2020 :
    No, why should I contact them? It is clear that the problem comes from my Oneplus 7 Pro 5G GM1920 phone, and not from Parrot.
  6. Artemus.
    Nougat Jun 8, 2020
    Artemus. , Jun 8, 2020 :
    It doesn't hurt to ask if it's supported.
