Camara issue via OnePlus 6
  1. AlokD
    Cupcake Apr 23, 2021
    AlokD , via OnePlus 6 , Apr 23, 2021 :
    It in my oneplus 6 there is suddenly one new shoe created like a I can't access my camera it suddenly stop working not even use camera in other application
    kunalsuthar likes this.
  2. Dresa91
    User of the Year 2016; Most Active User 2020 Apr 23, 2021
    Dresa91 , Apr 23, 2021 :
    Can you please clear cache and data of the camera app?
    Caoimhín likes this.
  3. Abhijith_Cherian
    Froyo Apr 23, 2021
    Abhijith_Cherian , via OnePlus 6 , Apr 23, 2021 :
    Hello Alok, I did not get your question clearly. I am guessing that the problem you are facing is that the camera app can't be opened. Can you please try clearing the cache of the camera app? If that doesn't work, please clear the storage as well. Hope that helps. Thank you.
  4. #4
  5. AlokD
    When i use camara its suddenly stopped working
  6. AlokD
    I want to use camera each and every time I want to clear cache data and also clear storage and after moment same issues, suddenly camara stop working
  7. AlokD
  8. Dresa91
    Can you please clear cache in recovery?
  9. sumitMZ007
    Jelly Bean Apr 23, 2021
  10. Abhijith_Cherian
    Froyo Apr 24, 2021
  11. G_Lorraine_Keane_mpjp
    Cupcake Apr 26, 2021
    G_Lorraine_Keane_mpjp , Apr 26, 2021 :
    I am facing the same issues - have cleared storage/cache and enabled and disabled and also cleared cache in recovery and still facing the same issue.
  12. Caoimhín
    OnePlus 9 Series Expert Community Expert Apr 26, 2021
    Caoimhín , via OnePlus 6T , Apr 26, 2021 :
    Do the following again first.
    Clear the Camera App info Cache and App info Storage
    Also Clear the OnePlus Camera Service App info Cache and App info Storage as well.
    Then go into Safe mode to check if the camera is operating normally there.
    Press the power button to bring up the power menu, now long press Power Off option you will get the option to boot into safe mode. Select OK
    If it is working boot back into normal mode, just reboot the phone
    The following may fix any issues of a 3rd party app causing the issue
    Reset the App permissions, it may be that an app or apps or something connected is causing the issue.
    Go to Settings > Apps & notifications > see all apps > select three dots > Reset app preferences.
    Then reboot.
    ⚠️This will not delete your apps data but you will have to provide permissions for all your Apps again.⚠️
    Check if this can help.
