camera app blackout and display calibration problems.
  1. Praisejesus
    Cupcake May 1, 2020
    Praisejesus , May 1, 2020 :
    The camera app gets blacked out when opened. And the display calibration is very bad, colours are pale and display looks over saturated.
    Please fix these issues ASAP. Thankyou
  2. Artemus.
    Nougat May 1, 2020
    Artemus. , May 1, 2020 :
    How can we help if you don't give us ANYTHING to work with?
    Caomhin likes this.
  3. JAGADISH BHATTA
    Jelly Bean May 1, 2020
  4. Caomhin
    Marshmallow May 1, 2020
    Caomhin , via OnePlus 6T , May 1, 2020 :
    Clear both the Camera App info Cache and App info Storage.
    Set your disolay calibration to AMOLED Wide Gamut in Advanced and set the Cold Warm slider to your preference, see if they help.
    Artemus. likes this.
  5. O1586331550560
    Eclair May 1, 2020
    Caomhin likes this.
  6. Praisejesus
    Cupcake May 10, 2020
    Praisejesus , May 10, 2020 :
    above: nokia 7 plus LCD panel
    below: op6
    colours look more yellowish and over exposed in the OnePlus. this is the issue
  7. Artemus.
    Nougat May 10, 2020
    Caomhin likes this.
  8. Praisejesus
    I have two issues (camera app crashes and display has yellow tint) . don't confuse the two. try helping or ignore lol
  9. Caomhin
    Marshmallow May 10, 2020
    Caomhin , via OnePlus 6T , May 10, 2020 :
    Bad comparison, totally different optics, camera and software.
    Try it with a GCam for OP6 see how that fares out, compare pictures taken with Gcam and the stock OnePlus camera.
    Dev Marco Gcam integrated XML files for 6 series phones.
    I have this one installed and it works very well.
    7.3_GCam_MJL_v4.1.1_Minilux.apk (marco, 2020-04-29, oneplus 6/6t, changelog)
    The XML are integrated, so no additional files required.
    https://www.celsoazevedo.com/files/android/google-camera/dev-marco/
  10. Praisejesus
    bro I compared only the colours here not the camera
  11. Praisejesus
    stock camera app kept crashing. And the display is yellowish.
    tried changing color temperature to the colder side still didn't help
  12. Caomhin
    So use AMOLED Wide Gamut in Advanced Display Calibration. Set the slider Cold, Warm to where you want it. Play with it, there are many options in there.
    Bouncer71 and Artemus. like this.
  13. JAGADISH BHATTA
    Jelly Bean May 11, 2020
    Artemus. and Caomhin like this.
  14. S1594458049842
    Cupcake Jul 26, 2020
    S1594458049842 , via OnePlus 8 , Jul 26, 2020 :
    Even I'm facing issues with the colour of pics. colours are different than original. but when pics are sent to other phones, they are looking good.
    please help with this
  15. Caomhin
    Marshmallow Jul 26, 2020
    Caomhin , via OnePlus 6T , Jul 26, 2020 :
    That may be down to your display, just means the camera is working well, but you need a different display calibration to view them on your phone.
    Go to Settings >Display>Screen Calibration and set your calibration to what suits your screen viewing preference. You can play with the settings until you find the one that suits.
    Just for reference, this is what I use on my 6T.
  16. S1594458049842
    but the screen calibration option is disabled. not able to access
  17. Caomhin
    Then there is an issue with your phone, are you logged in as a Guest on the phone or with the main account if there is more than 2?
    If as a guest account, some Settings may be disabled. Make sure you login to the phone with your main account.
  18. S1594458049842
    I logged in with my account only. Not any guest.
  19. Caomhin
    All Settings should be available to you. Either something gas locked you out of those settings, maybe an app you have installed, or Android is not functioning correctly as you should have access to screen calibration. There are a few settings in there that can be adjusted to suit your viewing options.
    Contact OnePlus directly to see why you cannot adjust those settings.
    contact OnePlus support directly to see if they have more information on your issue. Scroll down the page for contact and online chat details.
