camera issue
  1. P1524065428643 Cupcake May 17, 2018
  2. E1513091705018 Honeycomb May 17, 2018
  3. E1513091705018 Honeycomb May 17, 2018
  4. the_o2 Lollipop May 17, 2018
    the_o2, May 17, 2018 :
    Where you posted and which type of update you want software update??
  5. the_o2 Lollipop May 17, 2018
    Try going into Settings --> Apps --> Application List --> Camera --> Storage --> Clear cache and clear data. Reboot. See if this fixes your problem.
  6. P1524065428643 Cupcake May 17, 2018
    P1524065428643, May 17, 2018 :
    i tried the same but no effect. i post yesterday that camera is getting pixelerate after the update. someone replied will get an update for this after 3-4 hours and for that i just now repost the same issue. please help.
  7. the_o2 Lollipop May 17, 2018
    That person was definitely joking, the update for camera is not looks like to come this month..
  8. the_o2 Lollipop May 17, 2018
    Meanwhile you can report here:
    https://forums.oneplus.com/feedback
  9. E1513091705018 Honeycomb May 17, 2018
    E1513091705018, May 17, 2018 :
    I tried even factory reset but after taking pics noise is there.when I zoom.in it denoising . I don't know why
    P1524065428643 likes this.
  10. the_o2 Lollipop May 17, 2018
    Are you talking about oil paint effect?
  11. E1513091705018 Honeycomb May 17, 2018
    I m also it category for camera
  12. E1513091705018 Honeycomb May 17, 2018
    no oil paint is also there default. but after clicking pics it's not processing for denoising . when I zoom in the noisy picture it denoising. when zoom out again noisy.
  13. E1513091705018 Honeycomb May 17, 2018
    I am also have this issue.when they will update
  14. the_o2 Lollipop May 17, 2018
    Can you post any example, like a normal pic and a screenshot of zoom in pic.
  15. E1513091705018 Honeycomb May 17, 2018
  16. jeremip11 Cupcake May 17, 2018
    jeremip11, May 17, 2018 :
    if by chance the camera is going in and out of focus then you have "Stage fright".
    download comodo and while the app is running the test click the three other buttons available at the bottom. the Query will return a "Not Found" in Google play. press back and keep clivkibg thill it goes away. stage fright virus can really only be maintained.
  17. amine9448 Donut May 17, 2018
    amine9448, May 17, 2018 :
    is the picture also whobbling while focusing ? my camera is whobbling and doing a strange sound , any body with the same wobbly grainy images ?
  18. jeremip11 Cupcake May 17, 2018
  19. jeremip11 Cupcake May 17, 2018
