camera issues
  1. GMont2018
    Cupcake May 22, 2019
    GMont2018 , May 22, 2019 :
    I did a system restart dye to camera shutting down when I pressed the icon. the selfie part of the camera stopped working as well. I noticed I do not have the latest version of the camera app - my husband has a 6t. the version I have is V3.0.37. can you help?
  2. drl431
    Marshmallow May 23, 2019
    drl431 , May 23, 2019 :
    Try clearing the data and cache for the camera app. Then restart the phone.
    All 3 steps and in that order.
    As to the version, that could be stable vs beta os and that is not an issue.
    buntycubal likes this.
  3. GMont2018
    Cupcake May 23, 2019
    GMont2018 , May 23, 2019 :
    I did that. issue not resolved.camera takes beautiful pictures but will shut down unexpectedly. can't do the selfie
  4. drl431
    So, to be clear, you restarted the phone right after clearing the data and cache?
  5. GMont2018
  6. drl431
    Ok, are you using the OP7 camera app?
  7. GMont2018
  8. drl431
  9. GMont2018
  10. drl431
    The camera app version in its info page. Though it looks like you are running 2 versions behind on OOS.
  11. GMont2018
    Cupcake May 24, 2019
  12. GMont2018
  13. drl431
    Marshmallow May 25, 2019
    drl431 , May 25, 2019 :
    Ok, you are on a 6 month old OOS, but with a new "beta" camera app. This could be your issue.
    The current stable OOS is 9.0.13.
    I would fist update; (Settings > System > System updates).
    Going this OTA route might require 2 updates on 2 separate days.
    After the system is up to date, clear the data and cache for the camera app, then restart the phone.
