camera issues
  1. AKAsmita_Bawiskar
    Cupcake Sep 13, 2018
  2. AKAsmita_Bawiskar
    AKAsmita_Bawiskar , Sep 13, 2018 :
    too much of washed and patchy images of one plus 5t .. have noticed this when the camera is zoomed.. not happy with the issue.. any solution anybody has.. please guide me.. check the below images.
  3. C1510949982550
    Froyo Sep 13, 2018
  4. AKAsmita_Bawiskar
    thanks for the suggestion.. can you help me.. how to raise the complaint..
  5. C1510949982550
    Froyo Sep 13, 2018
    C1510949982550 , Sep 13, 2018 :
    I found the easiest way was to go to one plus website and go to support section. You can raise it there. Will need to be logged in with an account.
    AKAsmita_Bawiskar likes this.
  6. AKAsmita_Bawiskar
    thanks a ton for the suggestion and help..
  7. C1510949982550
    Froyo Sep 13, 2018
  8. Herbert_Lagos
    Jelly Bean Sep 13, 2018
    Herbert_Lagos , Sep 13, 2018 :
    OMG.... On cellphones it is normal to have oilpaint effect when you zoom in so much.... It's digital zoom not optical.
    See following zoomed in shots from iPhone X... same story.
  9. I_am_Batman
    KitKat Sep 13, 2018
    I_am_Batman , Sep 13, 2018 :
    No, They don't care. They don't want OnePlus to be iphone. They don't want oil painting. They paid for the phone with everything they have with the sole purpose of camera while they could have easily bought a DSLR.
  10. Herbert_Lagos
    Yep... But maybe one among hundred does care and will understand what I try to explain...
    I_am_Batman likes this.
  11. Frederik_Daniel7
    Eclair Sep 13, 2018
    Frederik_Daniel7 , Sep 13, 2018 :
    The camera doesn't have OIS, results in that kind of image...., try using tripod or GCam for better results, keep trying bro...
  12. Frederik_Daniel7
    Eclair Sep 13, 2018
    Keep learning bro, this is just a bad example of image, just ignore it
  13. itskiran2000
    Honeycomb Sep 13, 2018
    itskiran2000 , Sep 13, 2018 :
    Insufficient light + digital zoom? any camera struggles with that deadly combo, use promode with all auto in situations like this
    Herbert_Lagos likes this.
