camera not working and flash not working
  1. Jaideepghosalkar
    Donut Nov 30, 2017
    Jaideepghosalkar , Nov 30, 2017 :
    my camera is not working since updating oreo showing error while opening and same with flash too
    is there any bugs ??
    Victor prathaban likes this.
  2. naveen007777777
    Donut Nov 30, 2017
    M1556867422655 likes this.
  3. G_Sumanth_Samig_MoES
    Cupcake Nov 30, 2017
  4. naveen007777777
    Donut Nov 30, 2017
    naveen007777777 , Nov 30, 2017 :
    Tried still not working man
  5. Jaideepghosalkar
    Donut Nov 30, 2017
    youtube too is not working ..i think there are lots of bugs behind oreo update
    i think oneplus will fixed it soon...till then we need to be patient
  6. drago12587
    Froyo Dec 1, 2017
    drago12587 , Dec 1, 2017 :
    just do a factory reset.. it help 10000%.. i do it 2x .. One app called Os X theme do that bug with camera and flaslight.. factory reset helps.. ( your personal data dont remove just system)
  7. Jaideepghosalkar
    Donut Dec 4, 2017
    Jaideepghosalkar , Dec 4, 2017 :
    done with that still not...
  8. JaKy_DiOs
    Cupcake Jan 30, 2018
    JaKy_DiOs , Jan 30, 2018 :
    Hi mate,
    I don´t know if you solved your problem but in my case was a connector of the camera, I tried factory reset and nothing, I went a technical mobile shop and they saw that had a connector unplugged or they saw me this...
  9. jtalati
    Cupcake Feb 21, 2018
    jtalati , Feb 21, 2018 :
    Facing the same issue. Initially I thought there was some problem with scsnscan app. Switched to other apps and the camera still didint work. Oneplus should give solution asap as this is very inconvenient and time consuming.
  10. Ash645
    KitKat Feb 21, 2018
    Ash645 , Feb 21, 2018 :
    have you tried third party camera apps?
    also, test out the camera and flash using *#808# factory mode to make sure it's not hardware related.
  11. nicovanbelle
    Cupcake May 17, 2018
    nicovanbelle , May 17, 2018 :
    I've sent my phone in for repair 2 months ago with the same issues.
    - No camera
    - No YouTube
    - No FlashLight
    - No Automatic Rotation
    It worked for a month (which is better than a factory reset because that only worked for 1.5 days) without issue but 2 weeks ago the problem reoccured.
    There are MAJOR issues with Android8 and the OnePlus 3/3T and they keep it silent.
    But that's fine by me as this is my very last OnePlus phone ever.
  12. K1540486407339
    Cupcake Dec 15, 2018
    K1540486407339 , Dec 15, 2018 :
    hi...am using one plus 6.... portrait mode of my camera is not working...pls help....I tried clearing cache...but no use
  13. rajpaldinesh
    Cupcake Dec 16, 2018
    rajpaldinesh , Dec 16, 2018 :
    Hi, i am also facing same issue of camera (back) and flash not working. Tried all possible options including factory reset.... But all in vain.
    I guess one plus deliberately injected this bug in 3/3T models to force users to switch to new models.
    But its gonna spoil the image one plus has created in the market since last 5 years.
    If some body from one plus team can revert on this serious concern, else we have to take it to higher authority/consumer court.
    I would request support from others..
  14. ykraj251
    Cupcake Aug 23, 2019
    ykraj251 , Aug 23, 2019 :
    Same with me
