Camera not working via OnePlus 3T Gunmetal
  1. kinqTy
    Cupcake Jul 9, 2020
    kinqTy , via OnePlus 3T Gunmetal , Jul 9, 2020 :
    Installed the latest camera version from 3rd party all site and now the camera refuses to work, just showing black screen and I can't go back to the previous version even after clearing data
  2. Horsault
    Nougat Moderator Jul 9, 2020
    Horsault , Jul 9, 2020 :
    If you flashed a version which wasn't made for your device, I'm afraid you'll have to factory reset your device, unless you'll even have to manually flash a complete new ROM.
  3. kinqTy
    Cupcake Jul 9, 2020
    Damn!! Would now have to stick to google custom camera app then
  4. Horsault
    Nougat Moderator Jul 10, 2020
    Horsault , Jul 10, 2020 :
    Factory reset is very easy. You just have to backup the data you wish to recover first.
  5. Tobikage
    Nougat Jul 10, 2020
    Tobikage , Jul 10, 2020 :
    if you installed the app , you should be able to uninstall it.
  6. kinqTy
    Cupcake Jul 10, 2020
    kinqTy , via OnePlus 3T Gunmetal , Jul 10, 2020 :
    Tried that but there is no uninstall there, just force stop and disable app. And I have done the disable but still not reverting to the old camera
  7. Tobikage
    Nougat Jul 10, 2020
    App info → Camera → Three dots right corner
    kinqTy likes this.
  8. kinqTy
    Tobikage likes this.
  9. kinqTy
  10. kinqTy
    Thanks for the help, but is there no camera update i can install that has portrait mode in it for my OP3T? I already have the mod Google camera tho
  11. Horsault
