4
Camera not working
  1. ErsatzHitman
    Gingerbread Feb 4, 2018
    ErsatzHitman , Feb 4, 2018 :
    Pls help camera is not working
    I have tried many times
    I have force stopped the app but still it is showing black
  2. MKT_IRFAN3735
    Jelly Bean Feb 4, 2018
    MKT_IRFAN3735 , Feb 4, 2018 :
    clear cache partition by switching off your op and press power button and vol down untill y0ur op vibrate
  3. MJ_Vikram
    KitKat Feb 4, 2018
    MJ_Vikram , Feb 4, 2018 :
    Clear Camera App data and check if its not helping then install some 3rd party camera app and check if its working if they are also not working then its Hardware issue..
  4. ErsatzHitman
  5. sachinyar
    Cupcake Feb 4, 2018
    sachinyar , Feb 4, 2018 :
    I tried but same issue, I am getting it after update, any fix for this?
  6. sachinyar
    Cupcake Feb 4, 2018
    on portrait mode it shows lens is covered error.
    and when we zoom in and out sometime it works, looks like camera switching issue, pls provide the fix
  7. MJ_Vikram
    KitKat Feb 4, 2018
    clean the camera lens and clear camera app data and try..
  8. sachinyar
    Cupcake Feb 4, 2018
    I tried all the way, like clear the app cache, clean the lenses etc... but no luck :(
  9. MJ_Vikram
    KitKat Feb 4, 2018
    if nothing is working then better to visit service center, but before doing that you can try with Factory Reset.
  10. MKT_IRFAN3735
    contact Oneplus customer care
    sachinyar likes this.
  11. sachinyar
    Cupcake Feb 4, 2018
    thanks, sure will check with them and will update this thread
  12. MKT_IRFAN3735
  13. sachinyar
    Cupcake Feb 6, 2018
    sachinyar , Feb 6, 2018 :
    I followed the below steps:
    1. clear camera app data and cache
    2. clear cache from setting->storage
    3. reboot
    4. clear cache again from setting->storage
    5. open camera
    it worked for me, what about you?
    nachogarrone and kunal.h222 like this.
  14. Cristal ramos
    Cupcake Oct 7, 2018
    Cristal ramos , Oct 7, 2018 :
    Im getting the same issue on my OnePlus 6 after the new android P update. The camera will not work properly sometimes it starts correctly and sometimes its black like your screenshot and I don't know what to do.
  15. MaximRay
    Cupcake Jan 22, 2019
    MaximRay , Jan 22, 2019 :
    I have same issue on my 5T. Camera does not work in every app that I've tried (camera app, messenger, camscanner). Tried wiping app and system caches several times but nothing helps.
  16. nachogarrone
    Cupcake Feb 5, 2019
    nachogarrone , Feb 5, 2019 :
    this worked for me!!! lifesaver! thanks
  17. pbergonzi
    KitKat Jun 7, 2019
    pbergonzi , Jun 7, 2019 :
    For some with not working camera or gallery--if you flashed the ROM through TWRP without properly wiping data and cache (swipe to factory reset), there is the possibility you have encrypted storage and don't realize it. It will probably manifest itself in other ways also, for example not seeing folders in the inbuilt file manager.
  18. F1519755341770
    Cupcake Jul 16, 2019
    F1519755341770 , Jul 16, 2019 :
    hi friend. this is what exactly happened to me. actually first my camera was gone and i wiped cache/dalvik from TWRP and some of my files in downloads folder are suprusingly gone. i'm not concerning about my files but do you think this is related to camera problem?
    ps. i have tried unbrick tool but not worked also.
  19. pbergonzi
    KitKat Jul 23, 2019
    pbergonzi , Jul 23, 2019 :
    You will do well in the XDA-Developers OnePlus 6T thread. Best to look for help there.
  20. G_Sandesh_Bankar_hNsV
    Cupcake Nov 15, 2019
    G_Sandesh_Bankar_hNsV , Nov 15, 2019 :
