4
camera potrait mode- subject detection issue via OnePlus 7
  1. G_Sandip_barcelonista_jB , via OnePlus 7 , May 30, 2020 :
    hello, ..
    I'm using oneplus 7 and currently having issue with potrait mode subject detection. whenever i try to take potrait shot. the whole image is gone blur or extremely unacceptable edge detection.
  2. Artemus.
    Nougat May 30, 2020
    Artemus. , May 30, 2020 :
    Are you using Photo or Portrait?
  3. #3
    M1582135327470 likes this.
  4. Artemus.
    Nougat May 31, 2020
    Artemus. , May 31, 2020 :
    I think your problem is, there's no defined background with your subject being so close to the wall.
    Bouncer71 likes this.
  5. #5
  6. Artemus.
    Nougat May 31, 2020
    Doesn't matter what it is, it depends on how close the subject is between the camera and the background. The further the background is relative to the subject delivers better-looking shots; this is why they're best done outdoors.
  7. T1588643846873
    Donut Jun 4, 2020
  8. Liehjan
    Lollipop Jun 4, 2020
  9. T1588643846873
    Donut Jun 4, 2020
    T1588643846873 , via OnePlus 7 , Jun 4, 2020 :
    it works on other object except person
    camera version 3.10.22
    I noticed this problem after this update .
    Previous version was worked proporly. I think only another update should fixed this problem.
  10. Liehjan
    Liehjan , Jun 4, 2020 :
    Try to focus on a human subject, and take a photo... Is that still not sharp?
  11. Artemus.
    Nougat Jun 4, 2020
    Artemus. , Jun 4, 2020 :
    Once again, look at the distinctions between distance of subject and background. The bike has a HUGE distance between the background while the human subjects aren't far enough to register.
  12. kinghaloman
    Ice Cream Sandwich Jun 4, 2020
  13. T1588643846873
    Donut Jun 5, 2020
    T1588643846873 , via OnePlus 7 , Jun 5, 2020 :
    I think this issue is happening to some oneplus 7 devices only . I have tried to click portrait shots from distance but it couldn't capture human faces but it capture other objects perfectly.
  14. bearpaw
    Cupcake Jun 7, 2020
  15. Rat3811
    Eclair Jun 8, 2020
  16. #16
  17. Bouncer71
    OnePlus 7 Pro Sample Shot Photographer Community Expert Jun 9, 2020
    Bouncer71 , Jun 9, 2020 :
    Hello everyone...
    If you believe that there's a problem with Portrait-Mode either https://forums.oneplus.com/feedback/
    Or In community App-> Profile->My Feedback would be the better place to report it... :)
    Here's some quick hints for better edge detection...
    As @Artemus. Already mentioned the software needs distance to distinguish between foreground and background...
    Too close and you'll get something like this...
    More distance..
    And with increasing distance more Bokeh... ;)
    In the background there shouldn't be too much going on so the subject is clearly distinguishable from it..
    No hard edges crossing the edges of the subject...
    Like in Post #7 or #15...
    Hope that helps... :)
    If you still think there's issues report as I mentioned... :)
    Cheers
    Bouncer71
    Artemus. likes this.
  18. #18
  19. nikobcn
    Cupcake Jun 14, 2020
    nikobcn , Jun 14, 2020 :
    As everyone is mentioning above, it's subject's detection with faces that is the issue, NOT the whole portrait mode.
    My OP7 stock camera can't produce focused portait as soon as it detects a face in the frame. Everything gets blurred out. Happened 20 minutes after moving to 10.3.3.
    So that's on the camera app.
  20. sharmila1994
    Cupcake Jun 15, 2020
