2
Camera Pro mode advanced presets
  1. X1511206666460
    Eclair Dec 13, 2017
    X1511206666460 , Dec 13, 2017 :
    I saw the presets options on the pro mode in the settings where you can select a combination of iso/shutter speed/ exposure etc. I see the use case for that but I still feel it is missing a big feature that probably everyone would use.
    Not everyone is going to carry a tripod and then click on that preset to select that. Selecting the preset by hand limits the use of anything else except tripod.What I think might really help is save a preset that would contain 2 or 3 defined profiles. For eg: A profile with ISO 600, Shutter speed 1/100 seconds. Profile 2 with ISO 100, Shutter Speed 5 seconds. And then when the user clicks a picture on a particular preset, the camera takes these pictures one after the other without any user intervention.
    I understand that handheld might not be okay for longer shutter speeds, but I can still use it in more situations. And even on tripods, such control will be actually more helpful.
    raghu6763 and pH7 like this.
  2. pH7
    Honeycomb Dec 13, 2017
    X1511206666460 likes this.
  3. hardeepx
    Gingerbread Dec 13, 2017
    hardeepx , Dec 13, 2017 :
    there is a icon C next to raw in the pro mode... doesn't that do the same thing.
  4. X1511206666460
    Eclair Dec 13, 2017
    Haha well hopefully other people like the idea too and one plus implements it.
  5. X1511206666460
    Eclair Dec 13, 2017
    You probably haven't used that yet. In the post I have written why the current presets (the C icon) you are talking about are not good enough. If the advanced presets I am talking about get implemented, you can have numerous profiles depending upon the situation. Maybe people can even share with others and other people can utilize those presets for better results.
    raghu6763 likes this.
