9
camera pro mode sucks
  1. prajnay0
    Ice Cream Sandwich Mar 15, 2018
    prajnay0 , Mar 15, 2018 :
    which phone model are u comparing op5 to I checked post #49 and it didn't mention the phone model and if the phone model has less mega pixel then op5 then obviously that phone is going to be brighter
  2. ChopperHead
    Gingerbread Mar 15, 2018
    ChopperHead , Mar 15, 2018 :
    zenphone selfi
  3. prajnay0
    that phone has 13mp camera compare to 16 more of op so that camera will be brighter then op5 but the details will not be as good as op5
  4. shreyasopeth
    Honeycomb Mar 15, 2018
    shreyasopeth , Mar 15, 2018 :
    I had to rest my case because-
    1) I don't have a Zenfone with me right now, to test your claims. Hence it is totally pointless to keep on the discussion without testing your claims about Zenfone.
    2) Range of Kelvin temperature works perfectly fine in my OP5. I find OP5 pro mode to be a gem when it comes to low light.
    3) I found you to be a weirdo, who asks for filters in pro mode (like seriously?), and a narcissist who wants slow motion in front camera so that you can shoot your hair move in slow motion (whaaaat??).
    ArmataReloaded, Xeny and otto2 like this.
  5. ChopperHead
    Am saying about the low light , and temp
    I never said anything about the cam quality
  6. prajnay0
    ya in low light zenpone selfie will be brighter compared to op5 but it will have less details and for the temp you should use a dslr camera and then see the temp difference not a 11k phone
    shreyasopeth and otto2 like this.
  7. ChopperHead
    so u are saying there is no use with temperature in OP
    If I am dealing with temp I need to use DSLR ??
  8. prajnay0
    no I am saying that to find that the difference in temp is accurate in op5, u need to use a dslr with same difference in temp and compare it side by side
    shreyasopeth likes this.
  9. jaivaghela
  10. jaivaghela
  11. jaivaghela
    jaivaghela , Mar 15, 2018 :
    Hey buddy I have to 100% disagree with you on the Kelvin issues, check out 2 photos below shot on pro mode with my wife's OnePlus 5. The top one was shot at 4000k and bottom at 5000k with all other settings on auto. There is a pretty significant difference. Maybe clear your camera cache and try again. The pro mode is actually pretty good if used properly.
  12. ChopperHead
    so I need to use a DSLR to compare op's temperature ??
  13. prajnay0
    yes because that comparison will be more accurate
  14. ChopperHead
    Is this your first phone having a manual/promode features ??
  15. ChopperHead
    I can use any dslr ??
  16. jaivaghela
    I have used pro mode on the OnePlus 5 and on my current OnePlus 5T. The whole reason for my reply was to show you there is a significant temperature difference at those two settings on the OnePlus 5 in pro-mode. You mentioned there was hardly any difference which is inaccurate.
  17. ChopperHead
    of course it is wen I campared it with my old phone
  18. jaivaghela
    Y1515657664064
    of course it is wen I campared it with my old phone​
    Which is a bit strange because the photo I have posted above shows a very noticeable difference. Kindly post some photos to make use better understand the issue you are having and show us the settings used between your old phone and your OnePlus 5
  19. ChopperHead
    check #49 someone asked me same exact thing and he just vanished after accepting that the images are good which is taken from my old phone
  20. shreyasopeth
    I'm here I didn't freaking vanish! Read my reply above
    jaivaghela likes this.
