Camera problem/Photos go green
  1. erk
    Froyo Jul 17, 2017
    erk , Jul 17, 2017 :
    This what happens when I try to take a photo.
    The small preview icon/window in the bottom right corner shows the actual photo,
    when I click it the photo goes all green.
    someone experienced this before?
    any solution how to fix this?
  2. erk
    Froyo Jul 17, 2017
  3. F_Yannick_Sans_aYOl
    Froyo Jul 17, 2017
  4. erk
    Froyo Jul 17, 2017
    did not work
  5. Deactivated User
    Jul 17, 2017
  6. erk
    Froyo Jul 17, 2017
    Using a secondary/alternative camera actually works.
    Thanks for advice.
    Anyway, is there any solution to fix the stock camera?
    Is this a known bug?
    Deactivated User likes this.
  7. Deactivated User
    Jul 17, 2017
    erk likes this.
  8. luuxter
    Froyo Jul 17, 2017
    luuxter , Jul 17, 2017 :
    As someone else already mentioned, using another camera app is a temporary fix for your problem. You could also perform a factory reset on your OnePlus 5, that is likely to fix the issue.
  9. erk
    Froyo Jul 17, 2017
