Camera resolution settings
  1. reverator
    Froyo Jun 29, 2016
    reverator , Jun 29, 2016 :
    Which one of the settings outputs the highest resolution? 4:3, 1:1 or 16:9? It's strange that they couldn't just write out the resolutions for each aspect.
    quaddropop likes this.
  2. Murman
    Jelly Bean Jun 29, 2016
    bojantomic and fabio978 like this.
  3. KejPik
    Gingerbread Jun 30, 2016
    KejPik , Jun 30, 2016 :
    I like fast format switching a lot. I miss such feature in most of camera apps (e.g. Google Camera is a disaster from this point of view). It would be nice to have a possibility to change default resolution, because I do not need to have huge photos with 16M resolution. I would appreciate some settings like:
    High: full resolution - 16M
    Normal: 8M-10M
    Low: 5M
  4. tnttrx
    Froyo Jul 4, 2016
    tnttrx , Jul 4, 2016 :
    even better, it would be nice to have a separate setting for vertical and horizontal photos: I prefer 16:9 for regular photos, but it looks ridiculous for vertical photos. for verticals, I would stick to 4:3
  5. quaddropop
    Honeycomb Jul 6, 2016
    quaddropop , Jul 6, 2016 :
    Looks like the only way of getting a proper working camera app would be to change to another app. Oxygen is almost as limited as Google's stock rom, if not even more limited by options (same goes for the camera settings)
  6. fneelav
    Cupcake Oct 16, 2016
  7. gregor senge
    Cupcake Oct 17, 2016
    gregor senge , Oct 17, 2016 :
    Well, that's the setting I'm also looking for. Where to change to smaller sizes? Or can anybody recommend an app supporting this?
  8. joseluisillo
    Cupcake Nov 18, 2016
    joseluisillo , Nov 18, 2016 :
    That's exactly the question I was
    going to ask. I just don't need to create 16 Mpx photos all the time, basically almost never. I just want to make photos that I can easily manage and send via Whatsapp, email, etc and backup.
    I would be happy with a 2 or 3 Mpx setting most of the time.
    The only option is to switch to another app. Now using Camera MX, but I'd like to be using the Op3 original camera app instead.
    Can we expect to have this implemented or no chance (I don't see much interest on this around, really)
    Cheers.
  9. stiffie
    Cupcake Dec 2, 2016
    stiffie , Dec 2, 2016 :
    Hi
    I have the same issue
    I like the câmara simplicity but, its to much
    We need the be able to choose the image resolution, the frame rate on video, simple stuff like that
    Please give us total control over settings like we had in the OP1 (my previous)
    Some basic filters will be nice too, but settings its fundamental
    Its really driving me nuts...
    Thank you in advance, for the update :)
    Cheers
  10. Rogel
    Cupcake Jul 4, 2017
    Rogel , Jul 4, 2017 :
    its been a year and still no update for changing resolution on photos? you can do better OP.
  11. enyon
    Eclair Aug 4, 2017
    enyon , Aug 4, 2017 :
    WOW no resolution settings for camera? That's like a basic thing.
  12. S1519471263695
    Cupcake Apr 29, 2018
  13. rashmiranjan4363
    Cupcake Jun 14, 2018
  14. MarkyPancake
    Honeycomb Jun 14, 2018
    MarkyPancake , Jun 14, 2018 :
    This is one of the reasons I prefer the ported Google Camera, as that lets you change the resolution, like the official version.
  15. 007me
    Eclair Jun 18, 2018
  16. leo98918
    Ice Cream Sandwich Jun 19, 2018
    leo98918 , Jun 19, 2018 :
    4:3 will allow your camera to use it's full amount of Megapixels, 16 MPs (15.9 MPs is what it might say sometimes).
    16:9 will only use 12 MPs I believe. 16:9 Is pretty much a cropped version of 4:3. If you want that 16:9 aspect ratio, then take a photo in 4:3 and then crop it to 16:9. This way you maintain as much detail as possible.
    007me likes this.
  17. R1512274214831
    Gingerbread Jun 19, 2018
  18. leo98918
    Also, if you want more features, try installing GCam. You can get it from XDA. Works REALLY well! That's what I'm using now.
    007me likes this.
  19. S1519471263695
    Cupcake Jun 19, 2018
  20. Elektrokater
    Cupcake Nov 28, 2018
    Elektrokater , Nov 28, 2018 :
    Very cool ! Thank you for that tip - i´ll use GCam from now on!
    Its a bit poor from OP not to give a possibility to change the resolution.
    That was one of the 1st options i was searching for.
