10
Camera Shutter Sound
  1. Nagaraj shanmugam
    Eclair Dec 25, 2018
    Nagaraj shanmugam , Dec 25, 2018 :
    If you don't know the solution for this issue means,you just move on.After so many mistakes only successful fulfill things are happened in every place.
  2. borft
    Jelly Bean Dec 25, 2018
    borft , Dec 25, 2018 :
    so people can test, to find bugs before the stable release
    Nagaraj shanmugam likes this.
  3. Jogi5
    Ice Cream Sandwich Dec 25, 2018
    Jogi5 , Dec 25, 2018 :
    That's why there are betas... We all test it for Oneplus...
    And if you find bugs, then report them. But NOT in the community... report them in beta topic or bug report...
    borft likes this.
  4. Nagaraj shanmugam
    Eclair Dec 25, 2018
    that's only happening now.now i had installed,so am facing this issue.after this they will fix that issue and release the updation.
  5. borft
    the beta build is not pushed to any user. you have to explicitly, manually install it. I don't get why you would install software on your phone, without knowing what it is.
    how hard is it to read, or simply Google....
  6. Nagaraj shanmugam
    Eclair Dec 25, 2018
    ok friend.tell me how to report them in beta topic or bug report ?
    Arunsh147 likes this.
  7. Waveform Modifier
    Marshmallow Dec 25, 2018
    Waveform Modifier , Dec 25, 2018 :
    If you are competent, you would know where.
  8. Jogi5
  9. Nagaraj shanmugam
    Eclair Dec 25, 2018
    I get notification on my mobile regarding updation.then only i install.
  10. borft
    that will only happen if you are already on the beta track
  11. Jogi5
    And anytime in near future the beta train will stop. And then you have to go back to stable version and perform a factory reset....
    Or you'll stay on a buggy beta....
  12. Raj Bhagwat
    Donut Dec 27, 2018
    Raj Bhagwat , Dec 27, 2018 :
    I cannot turn shutter sound off in OnePlus 5t after android pie update...is there any way???
  13. Deactivated User
    Dec 27, 2018
  14. Pratyush_Agarwal
    Eclair Dec 27, 2018
    Pratyush_Agarwal , Dec 27, 2018 :
    Camera shutter sound is not turning off neither by turning off from camera app nor by making phone silent.
  15. bharathshetty4
    Cupcake Dec 27, 2018
    bharathshetty4 , Dec 27, 2018 :
    I have raised the same problem last week. This change was made by google because of some security changes and we cannot change it at this. moment
  16. sajithm
    sajithm , Dec 27, 2018 :
    Looks like the problem persists in the final build as well. Turning off the shutter sound has no impact in either the stock camera, or open camera. Tried clearing application data, didn't help. Using OnePlus 5 with build A5000_23_181223.
  17. ChiranthAtharvaa
    Gingerbread Dec 27, 2018
    ChiranthAtharvaa , Dec 27, 2018 :
    that's not a bug mate . it's legal requirement law in India now, we can't disable the shutter sound at all . personally I'm also not ok with this feature .
  18. Mr_Cyrox
    KitKat Dec 27, 2018
    Mr_Cyrox , Dec 27, 2018 :
    Nice find
    Search does wonders
    #38
    stark2991_PL likes this.
  19. domestoboto
    domestoboto , Dec 27, 2018 :
    SolarEclipse
    Thank goodness now people will know when you are trying to take secret photos of them.​
    All the more incentive for security personnel to harass you when you're trying to take a picture inside a Uniqlo or Ikea store.
    The best you can do at this point is use a third-party camera app such as the GCam ports or VSCO/Instagram/Snapchat.
    #39
  20. stark2991_PL
    KitKat Dec 27, 2018
    stark2991_PL , Dec 27, 2018 :
    You are from India, right?
    Shutter sound cannot be disabled in Pie if you are from India.
    #40
