10
Camera Shutter Sound
  1. KushalMys
    Eclair Dec 30, 2018
    KushalMys , Dec 30, 2018 :
    After pie update shutter sound enable and disable in camera is not working. even though shutter sound is disabled shutter sound is coming. I have cleared cache of the app also wiped cache and restarted.
    #61
    X1517396854503 and vishal602 like this.
  2. vishalnewton
    Froyo Dec 30, 2018
    vishalnewton , Dec 30, 2018 :
    I Turned Off the Shutter Sound In Camera Settings But It Didn't Worked, it's still there. Anyone here who can help with it
    #62
    X1517396854503 likes this.
  3. B_Wrath
    Nougat Dec 30, 2018
    B_Wrath , Dec 30, 2018 :
    What is wrong with discussing in the update announcement thread?
    Also, a simple search would have given you the answer!
    #63
    F_Divyesh_Kumar_AZXU likes this.
  4. vishalnewton
    Froyo Dec 30, 2018
    reply only when you know the solution, Otherwise don't :)
    #64
  5. B_Wrath
    Nougat Dec 30, 2018
    Create a thread only when it is not asked before, otherwise don't:)
    #65
  6. vishalnewton
    Froyo Dec 30, 2018
    you don't own this community, and don't create mess here. Go And Get a life
    #66
  7. B_Wrath
    Nougat Dec 30, 2018
    The same applies to you. You don't own this community, and don't create a mess here. Go and read the forum rules.
    #67
  8. Pradeepreddythada
    Eclair Dec 30, 2018
    #68
  9. vishalnewton
    Froyo Dec 30, 2018
    don't you have any work in your life, other than arguing with people.
    #69
  10. vishalnewton
    Froyo Dec 30, 2018
    yeah. agree with you broo..
    #70
  11. B_Wrath
    Nougat Dec 30, 2018
    Well. I like to spend my free time here. But I do get pissed off by rule breakers like yourself.
    #71
    Mr_Cyrox likes this.
  12. Pradeepreddythada
    Eclair Dec 30, 2018
    #72
  13. vishalnewton
    Froyo Dec 30, 2018
    don't reply here if you don't know the solution, let other people answer here, Non sense Boy
    #73
  14. B_Wrath
    Nougat Dec 30, 2018
    I know the solution and I told you where to find it.
    Don't expect to be spoonfed always. Do a little research on your own.
    #74
  15. vishalnewton
    Froyo Dec 30, 2018
    it's useless to argue with you, keep on replying :)
    #75
  16. B_Wrath
    Nougat Dec 30, 2018
    You say it is useless, but you still reply anyways.
    #76
  17. agrank29
    Cupcake Dec 30, 2018
    agrank29 , Dec 30, 2018 :
    Can't download apps from play store. It is showing "downloading.." for more than 30mins and still the same. Network is working fine. A le to download other stuffs at more than 20mbps. This issue was there in the open beta 23. Reverted back to stable one. and facing the same here.
    #77
  18. F_Vikash_Rajput_cwrX
    Froyo Dec 30, 2018
    F_Vikash_Rajput_cwrX , Dec 30, 2018 :
    it's been a while that the Android pie update has arrived for OnePlus 5/5T and users are facing some bugs or issue after the update. so just curious to know that when will a hot fix update will come to resolve these bugs ?
    #78
    X1517396854503 and slmnanwr like this.
  19. Waveform Modifier
    Marshmallow Dec 30, 2018
    Waveform Modifier , Dec 30, 2018 :
    Doubt it
    #79
  20. stark2991_PL
    KitKat Dec 30, 2018
    stark2991_PL , Dec 30, 2018 :
    Are you from India? If yes, then shutter sound is mandatory for your Country now (at least it seems so)
    #80
