10
Camera Shutter Sound
  1. KushalMys
    Eclair Dec 30, 2018
    KushalMys , Dec 30, 2018 :
    yes I am from india. but I haven't seen or heard anything like that
    #81
    X1517396854503 likes this.
  2. stark2991_PL
    KitKat Dec 30, 2018
    stark2991_PL , Dec 30, 2018 :
    Probably only in two months.
    Shutter sound always on is not a bug (at least it seems so)
    #82
  3. navaneethg
    Cupcake Dec 30, 2018
    navaneethg , Dec 30, 2018 :
    Unable to disable camera shutter sound is oneplus 5t after android 9 update. Radio buttons in camera setting is not helpful. Either way shutter sound is present. FYR/A.
    #83
  4. JamesBoulder
    Honeycomb Dec 30, 2018
    #84
  5. Budruel
    KitKat Dec 30, 2018
    Budruel , Dec 30, 2018 :
    I got no problem.
    #85
  6. P1508948437519
    Donut Dec 30, 2018
    #86
  7. static0
    Donut Dec 30, 2018
    static0 , Dec 30, 2018 :
    I had the same issue with the Pie Open Beta. It just solved itself after some time. Just let the download in Playstore run and eventually it will start downloading after some time. At best start with downloading a small app. After one download started, the rest was downloaded successfully and I never had the issue again.
    #87
  8. agrank29
    agrank29 , Dec 30, 2018 :
    I did. After few attempts, the download started. But the problem persisted in my case. Sometime It worked after I restarted the phone.
    #88
  9. Raja_Ram_Agarwal
    Eclair Dec 30, 2018
    Raja_Ram_Agarwal , Dec 30, 2018 :
    even i was facing the same problem in 6t, but after factory reset my problem is solved. This solution was given by one plus customer care.
    #89
  10. JamesBoulder
    JamesBoulder , Dec 30, 2018 :
    It is good for you if you don't have problem, I have faced the problem and I have reported it.
    #90
  11. agrank29
    I thought so. I did a factory reset.. complete data + cache clean. No relief. Issue remains.
    #91
  12. Budruel
    KitKat Dec 30, 2018
    It's correct.
    #92
  13. J1517984951185
    #93
  14. nikki_12
    nikki_12 , Dec 30, 2018 :
    plz help me to turn off shutter sound after pie update..it is not working even after turning off
    #94
  15. Rakesh_Kumar_T
    Jelly Bean Dec 30, 2018
    Rakesh_Kumar_T , Dec 30, 2018 :
    Europe and Asian governments have law that prevents people from taking photos of others without their consent , this is why shutter is enabled all the time
    #95
  16. Gannu619
    Gannu619 , Dec 30, 2018 :
    Google Play services using 90%. What the actual F?
    anyone knows how to stop it or its better to downgrade to Oreo.
    #96
  17. Raja_Ram_Agarwal
    Eclair Dec 30, 2018
    #97
  18. pablofg1978
    Nougat Head Moderator Dec 30, 2018
    pablofg1978 , Dec 30, 2018 :
    Please use the pinned battery thread in this section for any battery related discussions
    Redundant thread closed and removed from public view
    #98
  19. AbhijeetJ
    #99
  20. Jugal chudasma
    Cupcake Dec 31, 2018
