412
Camera Update of Oxygen OS 9.5.7 for OnePlus 7 Pro
  1. ZodRules12901
    Gingerbread Jun 8, 2019
    ZodRules12901 , Jun 8, 2019 :
    this is an outstanding update. I agree with many of the comments that there is still more work to do. I do wish there were some comparison selfie photos because I think that camera really needs help. the telephoto lens still isn't perfect and could use some tweaking. the double tap is much better. I think this is a great update and hopefully there will be a few more to come.
  2. Adex0ne
    Ice Cream Sandwich Jun 8, 2019
    Adex0ne , Jun 8, 2019 :
    You have to be grateful having an OEM listening to users , that's the basis, and here they are with feedback, get the point.
  3. Adex0ne
    Use a VPN and set to Germany, you should get it
  4. Michelin18
    Eclair Jun 8, 2019
  5. baggz143
    baggz143 , Jun 8, 2019 :
    Hur gör man med VPN
  6. O1560018369584
    Cupcake Jun 8, 2019
  7. Michelin18
    Eclair Jun 8, 2019
    Michelin18 , Jun 8, 2019 :
    are you in the US?
  8. O1560018369584
    Cupcake Jun 8, 2019
  9. Swejuggalo
    KitKat Jun 8, 2019
    Swejuggalo , Jun 8, 2019 :
    If your phone is branded by your carrier you need to wait for them to release the update
    O1560018369584 likes this.
  10. Michelin18
    Eclair Jun 8, 2019
    usa
  11. O1560018369584
    Cupcake Jun 8, 2019
    O1560018369584 , Jun 8, 2019 :
    let's see[e]1f604[/e]
  12. Michelin18
    Eclair Jun 8, 2019
    yes is a T-Mobile Branded phone.
    not even using that app oxygen installer works.
    i guess i haves to wait till T-Mobile gives the green light
  13. O1560018369584
    Cupcake Jun 8, 2019
    yes ..u are right..
  14. Michelin18
    Eclair Jun 8, 2019
    curious question
    why is that??
  15. O1560018369584
    Cupcake Jun 8, 2019
  16. Swejuggalo
    KitKat Jun 8, 2019
    Finns många appar till detta. NordVPN är ett exempel. Det viktiga är att den har servar i tex Tyskland eller ett annat land där man börjat rulla ut uppdateringen. Har man installerat en app och kopplat upp sig mot Tyskland så tror telefonen att du befinner dig i Tyskland. Då kan du få uppdateringen snabbare. Finns några som är helt gratis om man är villig att offra hastigheten men det ska ju duga till temporära behov. Opera hade en som var rätt ok men långsam. Verkar vara borta numera. Sök på Free VPN så hittar du nog någon som funkar.
    Använder man Oxygen Updater så laddar man ner filen oavsett vart man befinner sig utan VPN. Sedan får man gå in i där man normalt sett kollar uppdateringarna och trycka på kugghjulet och välja lokal installation. Då ska man se filen man laddat ner.
    baggz143 likes this.
  17. Michelin18
    Eclair Jun 8, 2019
    what do you mean nothing is serious
  18. O1560018369584
    Cupcake Jun 8, 2019
    there is nothing currious things..
  19. LarsdaYakha
    Eclair Jun 8, 2019
    LarsdaYakha , Jun 8, 2019 :
    ZOOM LENS TEST in outdoor lighting conditions on a cloudy day. I've found I get best results with HDR set to auto and "smart scene selection" turned off.
    color saturation and temperature issues as well as detail level and HDR between standard lens and telephoto have been resolved. I am very very impressed with the work the OnePlus camera team has put into this update. bravo! give these people a raise OnePlus.
    with this first shot of plant with purple flowers I moved forward with the standard lens to get to about the same distance
    standard lens
    10x hybrid zoom. very useable image, very detailed not too much noise
    standard lens
    3x zoom
    10x digital hybrid
    I included this image to show I know a thing or two about good images. I drew this. again bravo OnePlus camera team, you are true artists. give those people a raise.
  20. Michelin18
    Eclair Jun 8, 2019
    in that case, do you know why
