399
Camera Update of Oxygen OS 9.5.7 for OnePlus 7 Pro
  1. AZLeatherneck
    Eclair Jun 11, 2019
  2. amitmasterhunk
    Gingerbread Jun 11, 2019
    amitmasterhunk , Jun 11, 2019 :
    download turbo vpn from playstore
    connect to germany or canada
    then go nd check for update.. [e]1f44d[/e]
  3. amitmasterhunk
  4. U1559759972987
    Cupcake Jun 11, 2019
    V1560165685313 likes this.
  5. roryrudy
    Froyo Jun 11, 2019
    roryrudy , Jun 11, 2019 :
    The camera 'over exposes' tooooo much. Once you reduce the exposure, images are way better
  6. rohangt
    rohangt , Jun 11, 2019 :
    is there a way to disable beauty mode in the OnePlus 7 Pro camera? it's messing up all my shots
  7. paritoshec
  8. Devvfata1ity
    Devvfata1ity , Jun 11, 2019 :
    battery drain has increased after this update. After two cycles I am still loosing 2-3% an hour during standby. Previously I was losing about 1% an hour on standby
  9. script
    Nougat Moderator Jun 11, 2019
    script , Jun 11, 2019 :
    I don't have a 7, but if I remember correctly, hdr is on by default. Maybe, if you turn that off in settings, that could help.
    Hope that helps:)
  10. rohangt
  11. marzmar89
    Eclair Jun 11, 2019
    marzmar89 , Jun 11, 2019 :
    I get the same as you sadly
  12. Jean_Riget
  13. Swejuggalo
    Jelly Bean Jun 11, 2019
    Swejuggalo , Jun 11, 2019 :
    You probably have a carrier branded version then.
    marzmar89 likes this.
  14. Swejuggalo
    As far as I know beauti mode only exist in selife cam
  15. rohangt
    it's enabled by default for me on the rear camera. faces look smoothed and without detail. either way there should be an option to disable it
  16. Swejuggalo
    Missed that the portrait mode on rear has it too. But there is a disable button for that. Regular automode has none though. Maybe it is enabled by default there too.
  17. S1559132575309
    S1559132575309 , Jun 11, 2019 :
    I pre ordered my oneplus 7 pro from the website in the UK. The 9.5.7 update started rolling out last week and I have still not received the update. Any ideas why????
  18. himan96
  19. Swejuggalo
    Try wiping cache and see if that solves it. No abnormal drain for me.
  20. khaf
    khaf , Jun 11, 2019 :
    is it just me or should a photo in that type of daylight be sharper and more detailed? I still like the update. I'll take any improvements.
