415
Camera Update of Oxygen OS 9.5.7 for OnePlus 7 Pro
  1. marzmar89
    Eclair Jun 12, 2019
    marzmar89 , Jun 12, 2019 :
    yea more than likely may slide.. TMobile not receiving crutial updates for the phone is upsetting
  2. VicTheInvincible
    Cupcake Jun 12, 2019
    VicTheInvincible , Jun 12, 2019 :
    how'd you find that out? that is a bummer
  3. marzmar89
    Eclair Jun 12, 2019
    just going by recency
    the last update they sent out for nighyscape. we didn't even get we got a security patch that's all. and now everyone is downloading the recent update and yet we still get device up to date
    VicTheInvincible likes this.
  4. dacatalyst41
    dacatalyst41 , Jun 12, 2019 :
    That's really disappointing to hear. I just bought the phone today and that has me reconsidering. A critical update like this shod be available shortly after. Maybe OnePlus needs to drop the camera as an app that's updateable through the app store?
  5. VicTheInvincible
    I hope it's just delayed for TMobile honestly. if it's not updated or if it won't I'll have to go back to Apple
  6. Saifmsk
    Eclair Jun 12, 2019
  7. FRJerome
    Ice Cream Sandwich Jun 12, 2019
  8. Swejuggalo
    KitKat Jun 12, 2019
    Swejuggalo , Jun 12, 2019 :
    Reminding about Oxygen Updater for those with unlocked non carrier branded phones. It allows you to manually download the update and install it as a local upgrade. That option is available behind the cog in the normal System Update.
    FRJerome likes this.
  9. FRJerome
    FRJerome , Jun 12, 2019 :
    Yes you should sell your op7 pro and pay for photo lessons
    You're the Mozart of photography
    Taking a gas station at night away from 30 meters and with your shade in the grass. Genious man.
    Just a pity you don't move a little bit during your shot. Would have given movement to this chef d'oeuvre. Blurry you'd have said.
  10. FRJerome
  11. FRJerome
    Do you guy know what a focal length is?
    32mm vs 50mm
    Do you know which one is better for portrait on professionnal camera?
    Do you know that the distance to take a picture depends on the focal ?
    No...
    That's why you're asking a stupid question
  12. stevevue
    Eclair Jun 12, 2019
    stevevue , Jun 12, 2019 :
    When is this update coming to the US for T-Mobile? This is my first time using One Plus devices, love the display, but the camera is... how do I kindly put it, trash... please continue to improve... if this doesn't get ironed out soon, I may be enticed to just go back to Samsung lol. Not only pictures, but I also just notice a lot of bugs with my device, please bring this update asap, it's getting quite annoying using this device with sub par picture and performance quality...
  13. khan.is.amir
    khan.is.amir , Jun 12, 2019 :
    X1560019301655
    So tell us
    You own a OPO 7 pro ?
    Be honest​
    lame comment.. ddnt xpct dis from u here. zoom in and see for yourself the quality.
  14. N1560319984618
    N1560319984618 , Jun 12, 2019 :
    When I start using portrait mode the camera just stops working and it gets shutdown while capturing in portrait,really bad experience and it still happens from start till now. Please look after it.
  15. O1560322942313
    O1560322942313 , Jun 12, 2019 :
    cuando llegará a España esa actualización. por qué la versión 9.5.5 las fotos salen bastante borrosas.
  16. Shafiqur016
    Honeycomb Jun 12, 2019
    Shafiqur016 , Jun 12, 2019 :
    how to clean install the oxygen os 9.5.7..? i have accidentally installed a different region update vpn. is there any way? i tried local upgrade but it shows a error message saying lower version package and it won't allow but its the same 9.5.7 update. why isn't it allowing?
  17. rajamcs
    rajamcs , Jun 12, 2019 :
    after update, I also noticed my screen goes dull automatically with ambient display. without changing position of mobile,if I turn off and on ambient display, display becomes bright. I am noticing only after this update. please advise
  18. Nishantgharat
    Eclair Jun 12, 2019
    Nishantgharat , Jun 12, 2019 :
    hello!! I have OnePlus 5T and I love OnePlus smartphones. I have only 1 question is that...
    Why does camera don't have much features in it?? ( not talking about camera performance, it is the best)
    I see others low budget smartphones camera they have more features (ie AI, Filters, etc)
    OnePlus should give all those features [e]1f612[/e][e]1f612[/e][e]1f612[/e]
  19. Swejuggalo
    KitKat Jun 12, 2019
    Different region? How? If you used an VPN and use the builtin updater it only finds what is compatible with your phone but just faster.
    If you used Oxygen Updater and manually choose wrong phone you might need to recover the phone the same way as if it was bricked.
    https://forums.oneplus.com/threads/...ide-for-a-hard-bricked-oneplus-7-pro.1041896/
  20. Shafiqur016
    my oneplus 7 pro is the chinese variant, originally shipped with hydrogen os, maybe the seller has flashed it to oxygen. but my region is near India, but after the 9.5.7 update via VPN it has been updated to European build. thats where my concern is. so should i use the MSM tool to flash to stock build hydrogen os or should i flash the international stock build first?
