Camera via OnePlus 6
  1. K1527781911035
    Cupcake Jun 16, 2020
    K1527781911035 , via OnePlus 6 , Jun 16, 2020 :
    Today I installed a new apk for camera which is of latest version 5.4.10.
    Now when I am trying to open the camera, it's not working at all. Also, I tried to installed to older apk version for camera. I'm not able to install that as well as I'm getting error "App not installed" while installing the older apk. Please let me know which version was installed earlier and the steps for installing older apk.
  2. Artemus.
    Nougat Jun 16, 2020
    Artemus. , Jun 16, 2020 :
    Long-press camera app, App info, tap three-dot pattern on top right, uninstall updates. Next time, do not manually update the camera. Just because it has a higher number does NOT mean it's meant for your device...
  3. K1527781911035
    Thanks for your help. I won't install any upgraded version of apps from next time until it comes with system update.
    Thank you so much. [e]263a[/e]️🤗
    cdnfarmer and Artemus. like this.
  4. Roger.T
    Ice Cream Sandwich Jun 17, 2020
  5. Stevo2112 , via OnePlus Community App , Jun 19, 2020 :
    Hi everyone. Looking for suggestions to issues in having with my OnePlus 7T McLaren phone. 1 The touch response freezes all the time. I find myself tapping the screen without getting a response. 2. The autofocus doesn't work on the camera. Any suggestions are greatly appreciated..
    shehtoo likes this.
  6. Caomhin
    Marshmallow Jun 19, 2020
    Caomhin , via OnePlus 6T , Jun 19, 2020 :
    Backup your phone, full factory reset, Delete All Data, as in wipe your phone completely, AND then COMPLETE the NEXT steps below to Optimize the phone.
    After Backing up the phone.
    Go to Settings,
    System,
    Reset Options,
    https://www.androidpolice.com/2020/05/14/how-to-back-up-your-android-phone-before-a-factory-reset/
    And here
    [e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️NEXT[e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️
    To Optimize the phone after a Reset, clear your recent apps, also set 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Artemus. likes this.
  7. E1594963114392
    Cupcake Aug 13, 2020
    E1594963114392 , via OnePlus 8 Pro , Aug 13, 2020 :
    I'm not satisfied with front camera of 8 Pro as it is not clear and getting more whitish when we take pictures in a room with a light. I cannot click pics of moving objects it is getting blurred. it is truely unacceptable for this price range.
    please provide any tips or solution to get it better.
  8. Caomhin
    Marshmallow Aug 13, 2020
    Caomhin , via OnePlus 6T , Aug 13, 2020 :
    This is 6 series thread, OP8 has different hardware and software for the cameras, check on OP8 threads.
  9. H1523864932853
    Cupcake Aug 21, 2020
    H1523864932853 , Aug 21, 2020 :
    Dear friend, I have the same problem
    when tried to follow above instructions there is no three-dot pattern to uninstall updates.i use 5t, please help
  10. Artemus.
    Nougat Aug 21, 2020
    Artemus. , Aug 21, 2020 :
    Did you manually update the camera app too?
    Caomhin and H1523864932853 like this.
  11. H1523864932853
    No, all of a sudden when I was on a video call front camera has stopped working
  12. Artemus.
    Nougat Aug 21, 2020
    Completely different problem than the OP had.
    Caomhin likes this.
  13. H1523864932853
    I'm sorry if this was inappropriate.
    The update I received was long back, post update there existed no problem. From yesterday the front camere has stopped working. not really sure if this was because of the update.
    I tried start camera in safe mode which did not help too.only thing I didn't do is factory reset. is there any other way that this can be fixed? Thank you so much for your time
