6
camera
  1. G_Syah_Simple_JONw
    Donut Aug 30, 2017
    G_Syah_Simple_JONw , Aug 30, 2017 :
    please guys.. hiw to fix the camera op3...
    its like blur when capture the picture...
    [e]1f62d[/e][e]1f62d[/e][e]1f62d[/e][e]1f62d[/e]
  2. F_Arpit_Kaushal_SZkF
    Cupcake Aug 30, 2017
    F_Arpit_Kaushal_SZkF , Aug 30, 2017 :
    Yes...since the recent update the camera is not focusing in auto as well as manual mode...it keeps on hunting for focus... how to fix it..Help
  3. Sandy_here
    Gingerbread Aug 30, 2017
    G_Oleg_Petrov_aUXi likes this.
  4. NeVeR_SeTTLe
    The Lab - OnePlus 6 Reviewer Aug 30, 2017
    NeVeR_SeTTLe , Aug 30, 2017 :
    Try wiping camera cache. Go to Settings - - > Apps - - > Camera - - > Storage - - > Wipe Cache
  5. G_Jeroen_Van_Wijnsberge_
    G_Jeroen_Van_Wijnsberge_ , Aug 30, 2017 :
    I have the same problem with my Oneplus 3 after the August update, I already tried to clean the cache of the camera app but that doesn't help. Any solutions?
  6. aquilla
    aquilla , Aug 30, 2017 :
    Have the same problem. I use the Google Camera now seems to help. Will try a clean flash maybe this helps as well.
  7. athaarv
    Jelly Bean Aug 30, 2017
  8. G_Jeroen_Van_Wijnsberge_
    The camera won't focus with any app, not the stock camera app or the Google Camera, even Snapchat won't focus.
    punphop likes this.
  9. aquilla
    Sounds like a hardware issue. Try to check your phone with calling *#808#.
  10. G_Jeroen_Van_Wijnsberge_
    I've done all the tests of the camera and it passes on all of them but obviously it still won't focus properly.
  11. aquilla
    Have you tried to clean the cache in recovery?
  12. aquilla
    I read about that it could be a hardware issue which can not be detected from the system. Guess you should contact the support.
  13. pritesh goswami
  14. theantz
    theantz , Aug 30, 2017 :
    No issues for me ...works like it was before, both stock and Google camera.
    though it still sucks on moving objects, captures blurred images - like it was doing since first day! kind of getting used to it ;)
  15. Amro alaa eldin
    Amro alaa eldin , Aug 30, 2017 :
    i have the same problem and i wiped cache from recovery mode and installed many camera apps but still have the same problem. but it sometimes focus on objects automatically and sometimes doesn't
  16. nik748
    Cupcake Aug 31, 2017
    nik748 , Aug 31, 2017 :
    Thank you for help. I've finally solved the problem with the camera after a downgrade to Oxygen version 4.0.3 and then I went back to the current version without any problems with the camera. All the best. [e]270c[/e]️
    Jezelle likes this.
  17. nik748
    Go to Oxygen 4.0 3 download site and then fix the problem with the camera. Neither did I go for two months before I did this. All the best
  18. Shruti_oneplus3
    Cupcake Sep 2, 2017
    Shruti_oneplus3 , Sep 2, 2017 :
    me too facing the camera problem..blurred images..have reset phone also still facing this issue..how to solve?
  19. Yerunkar11
    Cupcake Sep 13, 2017
    Yerunkar11 , Sep 13, 2017 :
    take backup of your OnePlus device and reset to factory default and check, if it still doesn't work then boot to recovery mode and wipe/ delete system cache and boot the device.
    it worked for me. :D
  20. joaopedros2
    Honeycomb Sep 13, 2017
