camera
  1. J1526962753226
    Froyo May 23, 2018
  2. dsmonteiro
    OnePlus Community Team Staff Member May 23, 2018
    dsmonteiro , May 23, 2018 :
    What device are you referring to?
    Can you please share a sample that shows your issue?
  3. J1526962753226
    Froyo May 23, 2018
    J1526962753226 , May 23, 2018 :
    oneplus6
  4. dsmonteiro
    Can you share a video where your issue can be perceptible?
    I'm also moving your thread to OnePlus 6 general support.
  5. J1526962753226
    Froyo May 23, 2018
  6. J1526962753226
    Froyo May 23, 2018
  7. dsmonteiro
  8. J1526962753226
    Froyo May 23, 2018
  9. dsmonteiro
    What do you mean by not working properly?
  10. J1526962753226
    Froyo May 23, 2018
  11. dsmonteiro
    Again, the camera shutter stays open for less time in super slow motion, so the image will always be slightly darker than in a regular camera mode.
    Still, you can try sharing a video in daylight so people can pitch in.
  12. J1526962753226
    Froyo May 23, 2018
  13. viveknaudiyal
    Gingerbread May 23, 2018
    viveknaudiyal , May 23, 2018 :
    There is flickering of light behind the object and I have tried it in different conditions. Cant upload as the upload limit is 2 mb
  14. J1526962753226
    Froyo May 23, 2018
  15. dsmonteiro
    That's probably due to the artificial lighting, which is usually what causes the flickering videos.
    You can upload as an unlisted video on YouTube and share the link.
  16. viveknaudiyal
    Will do and also take a slow motion outdoors in daylight.
    But does your feedback mean that slow motion is useless indoors and can be used only outdoors
    dsmonteiro likes this.
  17. dsmonteiro
    Can't really try to see if I have the same issue, considering I don't have a OnePlus 6, but there are anti-banding techniques to remove that effect, so maybe OnePlus can fix that via software.
    Once you share the links I will forward this information to OnePlus.
  18. viveknaudiyal
    Please find the link
    Also to mention while recording a slow motion the brightness dims to almost 50% in the video. I have deleted all the other ones I had as the results were very bad. Will take some more samples and share tomorrow
  19. J1526962753226
    Froyo May 23, 2018
    exactly the same error I am dealing with even I have to delete all my slow mo videos it need to be fix asap
  20. Fredman
    Gingerbread May 24, 2018
    Fredman , May 24, 2018 :
    Try shooting in daytime with the curtains open.
    What your seeing is a flicker caused by mains powered lightbulbs. The light pulses at 50hz which is too fast for our eyes to see, but when you slow down the footage by a factor of 16 (youtube says playback is at 30fps) you see a 3hz flicker(dims and brightens 3 times a second). Given the green-ish tint, the light it is probably a CFl (compact flourescent) bulb.
    If you have to shoot indoors without any natural light try changing the bulbs to a high lumen rated LED bulbs (at least 1500 lumens, and preferably 6500k colour). LED bulbs run at a much higher frequency than CFl fixtures (usually about 40khz), and produce far more light per watt.
    viveknaudiyal likes this.
