Can charger slot be replaced in OP6T?
  1. Akshat Mongia
    Donut Feb 24, 2021
    Akshat Mongia , Feb 24, 2021 :
    My phone is 2 years old now and still working superb. I don't I need to change device till next 2 more years. But the problem emerged as my charging slot in phone has become wide enough that it doesn't accept my type-c cable. Please let me know that is it possible to change the charging slot? And if yes, what will be the cost of it in Indian Rupees?
    Thanks in advance
  2. B_Wrath
    Nougat Feb 24, 2021
    B_Wrath , Feb 24, 2021 :
    First try to clean the port. Its usually dust accumulation.
    Use a thin plastic tool and scrape it out.
  3. Liehjan
    Marshmallow Feb 24, 2021
    Liehjan , Feb 24, 2021 :
    It's possible to replace yes, but I don't know the cost... Please contact service center.
    Bobbie63 likes this.
  4. camohan
    Moderator Moderator Feb 24, 2021
    camohan , Feb 24, 2021 :
    Check the cleaning part. If it doesn't work, you can reach out to service centre to replace it.
    I think this will come under hardware adjustment and it should taken ~ Rs. 500 plus some labour charges.
    Have a look here https://www.oneplus.in/support/repair-pricing/details?code=9
    This seems to be a ball park number, actual charges may depend on final diagnosis by the service centre.
    McJader likes this.
  5. Akshat Mongia
    Donut Feb 24, 2021
    I cleaned it already. Slot has become so free that the 'click' sound when charged inserted doesn't come.
  6. B_Wrath
    Nougat Feb 24, 2021
    Ya. That's because dust and lint are jammed in the bottom of the port. Pry it out.
  7. startekselva
    Froyo Feb 25, 2021
    startekselva , via OnePlus 6T , Feb 25, 2021 :
    Don't pry anything use contact cleaner spray buy from local hardware store or Amazon or eBay it's simple and please don't pry the type c port is fragile use 1inch soft brush along with contact cleaner it will fix your issue
  8. Paccman
    Froyo Feb 26, 2021
    Paccman , via OnePlus 6T , Feb 26, 2021 :
    Before you decide on changing the part, find someone who has a new cable and see if you get that click sound when inserted into the phone. Could be the cable that's the problem.
  9. Tokolozi
    Most Original Avatar Feb 26, 2021
    Tokolozi , Feb 26, 2021 :
    Contact cleaner spray can be very corrosive, I would not use it on a phone.
    McJader, B_Wrath and Auristic like this.
  10. startekselva
    Froyo Feb 26, 2021
  11. Tokolozi
    Then it's best to just use plain Isopropyl Alchohol, which evaporates quickly and is not corrosive to electronic parts.
  12. Akshat Mongia
    Donut Mar 4, 2021
    Akshat Mongia , Mar 4, 2021 :
    I bought new cable and charger as well. no click sound there. the port is 2 years old and I think its time to change it.
  13. Raza_Dawar
    Gingerbread Mar 4, 2021
  14. Dipjyoti Nath
    OnePlus Bug Hunter Staff Member Mar 4, 2021
    Dipjyoti Nath , Mar 4, 2021 :
    We've got in touch with you via personal conversation to give you more insights regarding this. Please check for the same.
    Regards,
    Dipjyoti
    McJader and Akshat Mongia like this.
  15. Akshat Mongia
    Donut Mar 4, 2021
    hey thanks for the concern.
