Can I charging with Nexus 6P ?
  1. Merlinlegend
    Eclair Jul 23, 2017
  2. bagpiper
    Ice Cream Sandwich Jul 23, 2017
    bagpiper , Jul 23, 2017 :
    It would most likely work but not recommended as the dash charger is setup to control the charge rate to the oneplus phone so you may damage the battery.
    sicunder likes this.
  3. zabihjan
    Honeycomb Jul 23, 2017
  4. Rubenabc
  5. DarkExistence
    DarkExistence , Jul 23, 2017 :
    You can, but you will not get dash charging, only slow charging ;)
  6. Merlinlegend
    Eclair Jul 24, 2017
    Merlinlegend , Jul 24, 2017 :
    Thanks. And I don't damage battery?
  7. Aashish.007
    Ice Cream Sandwich Jul 24, 2017
    Aashish.007 , Jul 24, 2017 :
    No battery damage surely!
    Merlinlegend likes this.
  8. Merlinlegend
    Eclair Jul 24, 2017
  9. Aashish.007
  10. Merlinlegend
    Eclair Jul 24, 2017
  11. Akrati sharma
    Donut Jul 24, 2017
  12. DarkExistence
    DarkExistence , Jul 24, 2017 :
    Nope, you wont damage the battery!
  13. ajit.sandhu
    Froyo Jul 24, 2017
    ajit.sandhu , Jul 24, 2017 :
    you can change with any type C cable and any adapter Samsung, motto any but don't do it cause it might affect battery life
  14. EthanDrossos
    Gingerbread Jul 24, 2017
  15. danielboca
    Froyo Jul 24, 2017
    danielboca , Jul 24, 2017 :
    Let's be clear, Dash is 5V x 4A = 20 Watt, very fast indeed but depending on the level of your battery it may reach or not that power (ie, if at 5% it will go allmost 20watt, if at 70% it will be less, there are graphs on the web). Dash is very good at going from nothing to 50-75/%.
    On the other hand, usb type c is standard 5V x 3A = 15 Watt, and if you use a standard compliant charger (I use one from Nexus 5X at work) it will actually charge pretty fast. It's not 20 watt but hey it's fast, as I said, Dash will not always be able to feed 20 watt because battery will not allow it in order to protect :)
    Just try yourself and do some measurements if you're in the mood :)
