Can I replace my battery with that one from the oneplus two(BLP597)?
  1. CrAcKeZ
    Honeycomb Aug 16, 2016
    CrAcKeZ , Aug 16, 2016 :
    Actually connector seems the same, dimensions are about the same(lower height and width but just a tad thicker) the only problem is the location of the connector, it's not a direct replacement
    If I need a new battery I will surely think of this swap, if I can make a ribbon-cable mod :D
  2. benthomp85
    Cupcake Sep 1, 2016
    benthomp85 , Sep 1, 2016 :
    So, has anyone actually done this?
    I am looking to put the OP2 battery in my OPO - they look the same.
  3. ppod
    Jelly Bean Sep 1, 2016
    ppod , Sep 1, 2016 :
    A hammer usually makes things fit together.
  4. benthomp85
    Cupcake Sep 1, 2016
  5. C1555866990524
    Cupcake Apr 21, 2019
    C1555866990524 , Apr 21, 2019 :
    I mistakenly bought the Oneplus 2 battery for my Oneplus 1 but thanks to the thread above I simply swapped the little pcb from a previous old 1+1 battery onto the new battery. It doesn't actually need soldering - on the battery I had the tags from the power unit were just crimped into the connections on the little pcb. All working fine although it seems rather slow to charge - but maybe that's better for the battery. John
  6. C1555866990524
    P.S. I have no idea why my name is shown as a string of numbers!
