Can no long connect to Chat Features in Google Messages? Stuck on Setting Up after verifying phone # via OnePlus 7 Pro
  1. wellkevi01
    Donut Apr 24, 2021
    wellkevi01 , via OnePlus 7 Pro , Apr 24, 2021 :
    Hello,
    I have recently ran into an issue using the Chat Features in Messages. I noticed that the Chat Features were disconnected yesterday and I have been trying to re-verify my phone number. I tap on "Verify Number", enter my phone number, and then it just gets stuck on "Setting up". I have cleared the data for both Messages and the Carrier Services apps about 10 times now and none have solved the issue.
    My phone is a OnePlus 7 Pro, running Android 11 on Oxygen OS 11.0.0.2.GM21AA. I'm using the latest Beta version of Messages from the Play Store. I even tried the non beta version and that didn't solve my issue either.
    Thank you for any help,
  2. rhyd1am
    KitKat Apr 24, 2021
  3. wellkevi01
    Donut Apr 24, 2021
    I only have one SIM(Straight Talk-AT&T) installed, so both calls and data are enabled on it. And yes, I've tried all the steps that Google recommended on their FAQ/Tips page.
  4. R1627170379442
    Cupcake Jul 25, 2021
    R1627170379442 , Jul 25, 2021 :
    Hello All. I have great news. My RCS is finally working. Here is how I did it, please read this very carefully. Read my original post in Recommemded Answer green color above link.
    You must disable chat on all previous devices by going here and (on bottom of this site) follow directions: https://messages.google.com/disable-chat
    Then you must TURN RCS CHAT FEATURES OFF in GM and wait exactly 10 days.
    If you turn RCS ON before 10 days are gone, the clock starts all over again for 10 days.
    You literally have to be patient and wait 10 days with the RCS OFF for 10 days.
    After 10 days, turn RCS ON and you will see CONNECTED !!!!
    I repeat to you again, STEP 1 is: You must deactivate all prior devices' GM phone number associations by following the bottom instructions on this site: https://messages.google.com/disable-chat and if you get error message like: contact your carrier or you requested code too many times, disregard it.
    Then STEP 2, TURN RCS OFF FOR 10 DAYS in GM and wait 10 days. If you potz around and turn on RCS in GM BEFORE 10 days are gone, you must start 10-days clock all over again! Just be patgient for 10 days.
    STEP 3: On day #10, Clear Cache in GM and turn on RCS and you will see that you are GREEN LIGHT in RCS as CONNECTED. The best thing to do for this step 3 is to: completely uninstall Google messages and completely uninstall Carrier Services and then reinstall Google messages and reinstall Carrier Services. If you do this in this step, your cash and Data will be cleared.
    I am an expert in this now as I have triued everything: Contacted carrier, contacted device manufacturer, uninstalled Carrier Services and Reinstalled Carrier services. This has nothing with the carrier nor device manufacturer nor Samsung nor Motorola nor OnePlus. This RCS trying to verify.... occurs because when you switched your device, or when you switched SIM, or when u ported a number, or when you activated Google account email on another device, you DID NOT turn OFF RCS in GM or did not turn OFF RCS in the native Messages App, and now Google's RCS sees that you have RCS active in multiple devices/accounts/phone numbers, in which RCS remained TURNED ON, and Google RCS Server gets confused. What you need to do is STEP 1, STEP 2 and Step 3. Step 1 will deactivate ALL the shmootz you created and Step 1 will DEACTIVATE ALL devices' and all phone numbers' and all accounts' RCS GM once and for all. Step 2 does the "reset with google". Step 2 takes you OFF of "blacklist" at google. I see some people waited 8 days-not good. You absolutely must wait 10 days (not business days) - 10 CALENDAR DAYS and the day you do step 1, and step 2 is day #1.
    And by the way: Please make sure you have CARRIER SERVICES INSTALLED AND UPDATED from Google Play Store as well as latest updates of GM, and please update your device firmware by checking for update in SOftware Update in Settings. Basically please update your device firmware and all device apps in Google Play Store all aroung before proceeding with Steps 1,2,3.
    Let me know, but dont tell me that it doesnt work because you did not wait 10 full days. You must wait 10 days and then reply here and let me know.
    If you are unable to send or receive messages on Google messages app, this post does not apply to you. What I recommend you do is to: completely uninstall Google messages and completely uninstall Carrier Services. Then reinstall Google messages and reinstall Carrier Services. Then contact your cell phone carrier and ask them to refresh your connection and make sure that your messages and data features are turned on on the carrier side and make sure that Short Code Programming is also turned on, on the carrier side. So make sure messaging, data and short code programming is also turned on, on the carrier side. And meanwhile do not touch the toggle for full 10 days. In 10 days toggle ON and u will be set.
    I wrote 3 steps: make sure you read this twice to fully understand and follow my directions.
    From now on, you need to understand the concept, to make sure that this RCS feature not turning on again never happens to you again, you FIRST must make sure that before you change your devices, or change SIM cards in devices, or change Google accounts in devices, you absolutely must make sure that the first thing you do is: TOGGLE RCS CHAT OFF in GM FIRST before changing devices, sims or accnts! Otherwise, the Google server will be very confused and will Blacklist Your account, your device and your phone number by yourhaving too many RCS features toggled on in GM everywhere. To get UNblacklisted and turning RCS back to ON, you must read the steps 1,2 and 3.
    When i say 10 days, i mean 10 calendar days, not 10 business days. Day #1 starts the moment you toggle OFF rcs and keep it OFFfor 10 calendar days.
    You absolutely must respect the 10-DAY TOGGLE OFF, as i explained to you in Step 2. This step 2 is the only step that will UN-blacklist your phone number, you GM, and your GM account from the Google server. Please respect the 10day toggle off. If you potz around with toggle, you will not have RCS, and your 10day clock will start all over again with every time u potz around with Toggle.
    ALSO: ON DAY # 10, WHEN YOU TOGGLE THE RCS ON, IN THE GOOGLE MESSAGES APP, THE GOOGLE MESSAGES WILL ASK YOU TO RE-TYPE YOUR CELL PHONE NUMBER TO VERIFY IT WITH GOOGLE (THAT SAME DAY 10), PLEASE RETYPE THE PHONE NUMBER VERY SLOWLY AND CORRECTLY-BECAUSE: IF YOU TYPE YOUR NUMBER INCORRECTLY, EVEN BY 1 DIDIGT, YOUR STEPS 1,2 AND 3 (WITH 10-DAYS TOGGLE OFF) MAY START AGAIN. PLEASE SLOW DOWN AND BE VERY CAREFUL WHEN YOU RE-TYPE YOUR CELL NUMBER INTO GM APP WHEN IT RE-ASKS YOU TO VERIFY YOUR CELL NUMBER ON THAT DAY #10. PLEASE SLOW DOWN AND BREATH SLOWLY WHEN TYPING YOUR CELL ON DAY 10 (AFTER YOU TOGGLE RCS on ON SAME DAY #10.)
