Can not copy any Data from my OPO to my PC
  1. DirtyButterBrot
    Froyo Oct 12, 2015
    DirtyButterBrot , Oct 12, 2015 :
    I can not copy any data from my opo to my pc.
    Everytime i copy something the windows explorer crashes.
    Tried on multiple PC's and with and without USB-Debugging.
    Help would be appreciated
  2. Tokolozi
    Most Original Avatar Oct 12, 2015
  3. DirtyButterBrot
    Froyo Oct 12, 2015
  4. DirtyButterBrot
    Froyo Oct 12, 2015
  5. malidan
    Nougat Oct 12, 2015
    malidan , Oct 12, 2015 :
    So no matter which PC you plug into the OPO crashes the computer. Cool
    As usual preliminaries first what's you setup.
    Both ends
  6. Tokolozi
    Tokolozi , Oct 12, 2015 :
    try OPO ADB drivers instead maybe?
  7. DirtyButterBrot
    Froyo Oct 12, 2015
  8. LifelessLewis
    Jelly Bean Oct 12, 2015
    LifelessLewis , Oct 12, 2015 :
    When the phone is connected to the PC. Go into the settings and click storage settings. Click the 3 dot menu in the top right and click on USB computer connection. Make sure that MTP is enabled.
  9. DirtyButterBrot
    Froyo Oct 12, 2015
  10. DirtyButterBrot
    Froyo Oct 12, 2015
    It already worked a few months ago, my phone is rooted.
    I want a new ROM and i am trying to get my data of the phone. Currently it is almost full 3GB left, so it could take a while, and i if i would copy it over WIFI it would take about a week...
  11. Deactivated User
    Oct 12, 2015
  12. DirtyButterBrot
    Froyo Oct 12, 2015
  13. Tokolozi
    I don't know about you, but that wont go to slow, if using N wireless at least.
  14. Gonzo01
    Lollipop Oct 12, 2015
    Gonzo01 , Oct 12, 2015 :
    do you have USB (android) debugging selected in developer options? if, no, set it, plug in phone and wait a moment to see confirmation message on your phone. check "always" option and then "ok". this might help, if you haven't tried it yet.
  15. DirtyButterBrot
    Froyo Oct 12, 2015
    I have a AC Router that supports up to 750mbit/s but there are only 4mbyte/s coming to my pc.
    @Gonzo01 i did try that.
    Currently i am trying to copy in the teamwin recovery. It does not lock that bad here...
  16. DirtyButterBrot
    Froyo Oct 12, 2015
  17. Gonzo01
    that's also a solution to access your files. it might be bit slower than the "normal" way, but for sure better than over WIFI :)
  18. Gonzo01
    yes, it always works but not always convenient to transferr quick stuff to pc. all these rebootings, etc :)
    Tokolozi likes this.
  19. Tokolozi
    That's weord with AC I get nearly 11MBs on download on my pc, does the OPO support AC?
  20. DirtyButterBrot
    Froyo Oct 12, 2015
