Can USB mass storage be enabled?
  1. 70challenger
    Froyo Jan 10, 2015
    70challenger , Jan 10, 2015 :
    go to storage then the upper right 3 dots - USB computer connection, click Media device (MTP)
    tanujb.maps likes this.
  2. vadimb
    Cupcake Feb 8, 2015
    vadimb , Feb 8, 2015 :
    You can have UMS functionality.
    Download DriveDroid.
    Download Terminal IDE
    In DriveDroid create blank image. Call it usbdrive.
    In Terminal IDE navigate to the image folder:
    su
    cd /sdcard/Downloads/images
    Format the image to FAT:
    mkdosfs -s 1 usbdrive.img
    At this point you be able to "activate" the image in DriveDroid and the computer will recognize it like a USB drive.
    Now, if you like me, stuck in a hotel room with nothing to wach on TV and dont have a laptop nearby but the TV has a USB input you have to populate the image with you're pirated tv shows first...
    In Terminal IDE:
    mkdir drive
    mount -o loop usbdrive.img drive
    cp ../some_movie.mp4 drive
    richemon85 and akincansenol like this.
  3. tanujb.maps
    Cupcake Feb 15, 2015
    tanujb.maps , Feb 15, 2015 :
    You the best.
  4. Skwij
    Froyo Feb 15, 2015
    Skwij , Feb 15, 2015 :
    No need for 3rd party sync apps with your Mac.
    Once USB drive is enabled simply drag and drop your files with Android File Manager app that you've downloaded to your Mac.
    Remember that your entire iTunes library exists in your Music Folder > iTunes > iTunes Music
  5. bharat.naidu
    Cupcake Mar 20, 2015
    bharat.naidu , Mar 20, 2015 :
    Bro, did you have any luck in restoring your lost data, my firmware crashed and I ended up losing all my pics. Want them to be recovered badly
  6. NIRAJ8797
    Cupcake Apr 21, 2015
    NIRAJ8797 , Apr 21, 2015 :
    Ya did the same mistake how did I get that option again.. Pls help
  7. scbjmshpv
    Eclair Apr 25, 2015
    scbjmshpv , Apr 25, 2015 :
    Hi, i had same problem, somehow didn't back up contacts on SIM card, has anyone able to use recovery from phone on MAC? do not have windows pc atm. would love some good news right about now.
  8. richemon85
    Cupcake Nov 30, 2015
    richemon85 , Nov 30, 2015 :
    I like the DriveDroid mouting hax. You guys are supposed to be geeks, how you are failing to backup your pix with dropbox and sync your contacts with gmail, is beyond me.
