Other Cancel indicator LED when charging
  1. F_Edi_Itelman_AbhW
    Donut May 1, 2017
    F_Edi_Itelman_AbhW , May 1, 2017 :
    Hi,
    When charging the phone the notification LED is always blue while charging (Or red if not using DASH) and always green when charged. This is not very indicative and really mostly distracting.
    Has anyone found a way to cancel the charging notification LED? I have tried using some apps but was unable to find the proper configuration.
    Thanks!
    bushongadong likes this.
  2. F_Diganta_Koner_WIXu
    Jelly Bean May 1, 2017
  3. G_Félix_Erol
    Cupcake May 1, 2017
  4. Sandeep varma
    Gingerbread May 1, 2017
  5. Scherpenseel
    KitKat May 1, 2017
    Scherpenseel , May 1, 2017 :
    I found this was easily done by removing the charging cable! Also turning the device on it's glass keeps the LED light away from sight.
    Tadkase likes this.
  6. saiksb
    Cupcake May 1, 2017
  7. JesseMach
    Cupcake May 1, 2017
    JesseMach , May 1, 2017 :
    If I try to change the color while charging, or doesn't work. It's always blue, no matter what color I choose. Anyone worn the same problem?
  8. bushongadong
  9. bushongadong
    bushongadong , May 1, 2017 :
    Yeah, I have the same question. I see the way to customize the LED color in settings but no way to shut it off.
  10. rickdogg82
    Cupcake May 1, 2017
    rickdogg82 , May 1, 2017 :
    Apparently when using the Dash charger the color will always be royal blue to indicate Dash charging. When charging in non-Dash mode you will see your selected color.
  11. Tadkase
    Cupcake May 2, 2017
    Tadkase , May 2, 2017 :
    [e]1f602[/e][e]1f602[/e][e]1f602[/e]
  12. G_Ameek_Gupta_SgHj
    Donut May 2, 2017
