Cannot flash recovery using cmd or powershell
Is this is because of windows 10 ???
  1. yes
    1 vote(s)
    25.0%
  2. no
    3 vote(s)
    75.0%
  1. Ranjithsmart
    Jelly Bean Dec 31, 2018
    Ranjithsmart , Dec 31, 2018 :
    I have my phone's bootloader is unlocked and i installed all the required adb and fastboot drivers properly.
    when type "fastboot devices" it shows the device attached,
    and also when i type "fastboot oem device -info" its shows the devices status.
    My problem is when i type "fastboot flash recovery xxx.img " it says that cannot load or too many links
    I also tried " fastboot boot xxx.img " it cannot boot into recovery it gives the same error.
    I tried with different twrp versions,I have also tried the same method on my both oneplus 2 and oneplus 3T,I tried different tools too but nothing helps.
    Hoping for your help guys....
  2. Horsault
    Nougat Moderator Dec 31, 2018
    Horsault , Dec 31, 2018 :
    I assume your PC is windows captive.
    You must provide the whole path to your .img file.
    You may try from another computer, preferably free from Win10.
    Ranjithsmart likes this.
  3. Ranjithsmart
    Yes i am providing whole path name i tried in different ways.
    I too thought the same i am going to try in different os and post the results here. But i want to know why 10 is doing this so?
  4. Horsault
  5. MANYA_1999
    Honeycomb Dec 31, 2018
    MANYA_1999 , Dec 31, 2018 :
    Can you post photos of command line or screenshots?People may be able to understand the problem better.
  6. Ranjithsmart
  7. athaarv
  8. Ranjithsmart
    What is root folder? I tried flashing by keeping it in local disk c, d and also in different ways like placing it in desktop.
  9. athaarv
    athaarv , Dec 31, 2018 :
    Copy the recovery file to C:/adb <--- that should be your root ADB folder
  10. Ranjithsmart
    Wait i will try that and tell you here. If that works really you are great dude!
  11. BeingIncog
    Nougat Dec 31, 2018
  12. Ranjithsmart
    Tried that too like twrp, stock, cm, twrp123, recovery not working.
  13. athaarv
    Do let me know if it works
  14. athaarv
    Did it work?
  15. Ranjithsmart
    Jelly Bean Jan 1, 2019
    Ranjithsmart , Jan 1, 2019 :
    Yes bro it works but it is not because of storage location.
    guess what ,its really a cheap thing ! I bought a new multi usb hub just for rs:190 ,And i connected the usb cable with that and tried flashing recoveries. When i randomly searched for the solution a youtuber said that " too many links " error in cmd is because of usb cable or port.When i unplugged cable and connected in laptop's usb port it works fine.
    ANYWAY THANKYOU.
    athaarv likes this.
  16. P1570539595942
    Cupcake Oct 8, 2019
    P1570539595942 , Oct 8, 2019 :
    FCKIN THANK YOU, was trying to solve this error for a lot of days now, did your method of using usb hub, it worked. thanks man
  17. Ranjithsmart
    Jelly Bean Oct 8, 2019
    Ranjithsmart , Oct 8, 2019 :
    I created this thread long back, But now this helps you! It makes me very happy dude [e]270c[/e]️.
  18. dudenugget2000
    Cupcake Jul 5, 2020
  19. Ranjithsmart
    Jelly Bean Jul 9, 2020
