2
Cannot use audio Tuner with Bluetooth headphones
  1. Jxbfs
    Gingerbread Nov 28, 2018
    Jxbfs , Nov 28, 2018 :
    When I tried using oneplus's audio Tuner with Bluetooth headphones it were grayed out. This setting is available in Sound and Vibration. Please fix or if there are any suggestions, please tell what to do
    Raresch and R1543430756989 like this.
  2. BMG1900
  3. YRJ
    The Lab - OnePlus 7T Reviewer; Community Hero 2020 Nov 28, 2018
    YRJ , Nov 28, 2018 :
    this issue has been addressed to and a fix for the same will come with the next update.
    hope that helps.
    also please use the search function before creating new threads. there exists threads on similar issues.
    BR,
    Yash [e]1f60a[/e]
  4. KeepTransisting
    The Lab - OnePlus 7 Pro Reviewer Nov 28, 2018
    KeepTransisting , Nov 28, 2018 :
    That's because the audio tuner is only meant for analog headphones, i.e. ones that plug into the jack.
    S1510327714183 likes this.
  5. Frostywuff
    Honeycomb Dec 4, 2018
    Frostywuff , Dec 4, 2018 :
    Audio Tuner not working with Bluetooth headphones isn't an issue, they didn't add that in.
