2
Can't connect to camera
  1. kaldic
    Eclair Sep 6, 2014
    kaldic , Sep 6, 2014 :
    Ahoj, našel jsem crasch při používání aplikace pro statické zobrazení - Smartstay Př. OPO nemohou obě aplikace najednou:-(
    #41
  2. Isab3lla
    Gingerbread Sep 6, 2014
    Isab3lla , Sep 6, 2014 :
    Cannot connect to camera? Nope, have not had that problem before.. I don't know if it's a Snapchat thing, since I don't use that but have you updated?
    #42
  3. TigerXC
    Lollipop Sep 6, 2014
    TigerXC , Sep 6, 2014 :
    reboot seems to help.
    I found some sports apps keep crashing.
    so I'm sure the bugs need to be ironed out for some apps.
    #43
  4. tom rietveld
    Cupcake Sep 6, 2014
    #44
  5. gmo8492
    #45
  6. Rankkuri
    Cupcake Sep 6, 2014
    #46
  7. Phaselocked
    Froyo Sep 22, 2014
    Phaselocked , Sep 22, 2014 :
    Any update on this? I first thought it was Snapchat too, but I noticed it always happens when you flip te camera to front cam (selfie-cam). As soon as I flip the camera it most of the time crashes the cam. The fix above works for me, BUT only for the normal cam, still can't flip the cam then it will crash again.
    #47
  8. iyad
    Cupcake Sep 22, 2014
    #48
  9. Phaselocked
    Froyo Sep 22, 2014
    Yes. It's the best phone I've ever had/seen. Even can't compare to the iPhone 6 IMO. The quality is exceptional. The price is so cheap. Had no issues but this one!
    #49
  10. michaeltrinh
    Froyo Sep 23, 2014
    michaeltrinh , Sep 23, 2014 :
    Same problem on my OnePlus One. I just emailed SnapChat. Hopefully they can fix the issue.
    #50
  11. giaur500
    Jelly Bean Sep 23, 2014
    giaur500 , Sep 23, 2014 :
    If stock app or google camera doesn't work you probably flashed wrong gapps
    #51
  12. ZoeyyeoZ
    Ice Cream Sandwich Sep 23, 2014
    ZoeyyeoZ , Sep 23, 2014 :
    I'm having this same issue... I tried rolling back to a dif. nightly, uninstalling all camera apps, as well as reinstalling gapps 4.4.4.... no luck.
    #52
  13. DrSpychology
    Froyo Sep 23, 2014
    DrSpychology , Sep 23, 2014 :
    I frequently have this problem, it's really annoying... Hoping this gets fixed eventually, I'm getting kinda sick of constantly rebooting my phone
    #53
  14. Antonjagerr
    Eclair Sep 24, 2014
    Antonjagerr , Sep 24, 2014 :
    Also have this problem very often... Seems to occur when snapchat is used. Really want a bugfix for this since it is really annoying.
    #54
  15. askar_asi
    Cupcake Oct 1, 2014
    askar_asi , Oct 1, 2014 :
    Also have this issue after update to 4.4.4 and XNPH33R. But I have no snapchat. Restart isnt helping. Reset also no good.
    #55
  16. tye359
    Ice Cream Sandwich Oct 1, 2014
    tye359 , Oct 1, 2014 :
    I also have the same problem - every time i use snapchat it crashes the whole camera API and i need to restart the phone; otherwise the battery starts to drain!
    #56
  17. krab19
    Eclair Oct 1, 2014
    krab19 , Oct 1, 2014 :
    I have had this issue on my One as well as my old Nexus 5 (which ran completely stock) when using snapchat. Unsure if it is OS related or app related, but if it were snapchat causing the problem then I would not be surprised :p But luckily a quick reboot fixes the issue
    #57
  18. leemartin
    Lollipop Oct 1, 2014
    leemartin , Oct 1, 2014 :
    I have not had this yet, but used to get it a lot on the first Moto G that I had. I guess its a hardware problem
    #58
  19. Army Chick
    Cupcake Oct 6, 2014
    Army Chick , Oct 6, 2014 :
    Since the beginning of this post it is still occurring! I just received my One plus One and it's still crashing like mad. After using any app like Instagram or Snapchat the camera crashes AND the flashlight. Also, having music randomly plays. Anyone else have this problem??? I will be in the middle of a meeting and all of a sudden my Pandora or IHeart will start playing. Not ok especially during formation with the military!
    #59
  20. Shroomaster
    Eclair Oct 9, 2014
    #60
