2
Camera Can't Disable Camera Shutter Sound - OnePlus 5
  1. Saif_Ghole
    Froyo Jun 29, 2017
    Saif_Ghole , Jun 29, 2017 :
    Hi All,
    have any one faced this issue ?
    Even the Camera Shutter sound is turned off from setting, the camera sound is audible.
    Bullo Oka and Chandan385 like this.
  2. Atlas400
    Cupcake Jun 29, 2017
  3. Vivekparsekar
    Cupcake Jun 30, 2017
    Vivekparsekar , Jun 30, 2017 :
    Doesn't work for me !!
    Even double-tap power button to capture doesn't work.
  4. Saif_Ghole
    Froyo Jun 30, 2017
    Saif_Ghole , Jun 30, 2017 :
    its seem only we both are facing with this issue :(
    Really disappointed with OnePlus 5. :(
  5. G_Shreyans_Parshwakirti_
  6. F_Itamar_Ben_Ezry_gVGF
  7. worm41
  8. Niranjana Karandikar
  9. dreamtoy
    Cupcake Jul 2, 2017
    dreamtoy , Jul 2, 2017 :
    use the notification button on the left side of the phone, slide it up to silent mode, the camera will not make a sound when taking a picture now.
  10. MatG-DK
    Gingerbread Jul 2, 2017
    MatG-DK , Jul 2, 2017 :
    I can turn off camera shutter sound, but the double tab power button to capture don't work for me as well
  11. Areebanwar
    Honeycomb Jul 2, 2017
  12. vamshise
    Cupcake Jul 4, 2017
    vamshise , Jul 4, 2017 :
    Same issue here as well. It's crazy. What's the point in providing an option to disable which doesn't reflect.
  13. Techno_Ali
    Cupcake Jul 4, 2017
  14. lethanhtran
    Froyo Jul 4, 2017
    lethanhtran , Jul 4, 2017 :
    Weird.. turning shutter sound off works for me, but I also have all sounds turned off under System.
  15. F_Ranbir_Singh_OaAl
    Froyo Jul 4, 2017
    F_Ranbir_Singh_OaAl , Jul 4, 2017 :
    Same issue here...not working with silent mode option on the phone too.. tried few troubleshooting steps as per call centre people but no luck...this is definitely some software bug issue which needs to be fixed or need to get phone replaced if possible if it's manufacturing defect....where can I write such genuine issue so that it reaches the right technical team of OnePlus..any ideas
  16. SadButTrue
    Ice Cream Sandwich Jul 4, 2017
    SadButTrue , Jul 4, 2017 :
    1. seems to be a android issue or an regulation according to indian laws (https://www.reddit.com/r/GooglePixel/comments/63jfsp/anyone_from_india_able_to_mute_camera_sounds/ and many others on google support forums)
    2. this IS an regulation to meet the indian law (3 times power - emergency call) https://source.android.com/devices/tech/connect/emergency-affordance
  17. harsh0604
    Eclair Jul 4, 2017
  18. gauravsood1991
    Froyo Jul 4, 2017
  19. shuzozo
    Cupcake Jul 6, 2017
  20. sumedhsharma
    Cupcake Jul 10, 2017
