20
Can't enable Voice Match
  1. abhishek2n00
    Cupcake Aug 6, 2018
    valdoaloquio likes this.
  2. G_עומרי_פרשי_ak
    Cupcake Aug 6, 2018
  3. kroekerj
    Cupcake Aug 6, 2018
    kroekerj , Aug 6, 2018 :
    Same issue. OP 3T.
    Recent Google update.
    Suspect it's a Google issue.. Really hope they fix it
    Highly annoying.
  4. patrice58
    Ice Cream Sandwich Aug 6, 2018
  5. xeon101
    xeon101 , Aug 6, 2018 :
    delete this previous recognition and retain it again by doing it yourself...or another approach is it is previously backed up you don't need to further instruct it...
    all you have to do is reset it...and it is ready to respond your voice...
  6. bosenko
    Cupcake Aug 6, 2018
  7. tommycuaca
    Donut Aug 6, 2018
    tommycuaca , Aug 6, 2018 :
    Your Solution is not working.
  8. Vamsi96
    Donut Aug 6, 2018
  9. avnerelizarov
    Cupcake Aug 6, 2018
  10. Q1512724678182
    Cupcake Aug 6, 2018
  11. jose19679
    Honeycomb Aug 6, 2018
    jose19679 , Aug 6, 2018 :
    the same on my one plus 5t it only recognize my ok Google voice from home screen after uninstall the Google app update in Google play. I'm on oos 5.1.4 stable
  12. harshilpatel1903
    harshilpatel1903 , Aug 6, 2018 :
    Calm down everyone.. This isn't OnePlus's fault, its google app's fault.. The latest update probably only the beta version seems to have disabled the voice detection.. And I guess they have acknowledged the issue too, so wait for the next update and see if it's solved..
  13. patrice58
    patrice58 , Aug 6, 2018 :
    If you can't get to it because it's greyed out then please tell me how to do that? Before you go there yes I've uninstalled and reinstalled and I've deleted all data for the Google app and reinstalled. So what else is there to try?
  14. tommycuaca
    Donut Aug 6, 2018
    mnstrmike likes this.
  15. patrice58
    No it's happening on the normal version as well as I thought installing that would fix the error. No chance!
    tommycuaca likes this.
  16. tommycuaca
    Donut Aug 6, 2018
    me too. Re installing the app is still not fixing the issue.
    patrice58 likes this.
  17. harshilpatel1903
  18. patrice58
    #38
  19. mnstrmike
    Cupcake Aug 6, 2018
    mnstrmike , Aug 6, 2018 :
    same here. before update i had I had been having horrid issues with Google Assistant. Would have intermittent issues with the prompts not playing a sound, would have to watch for icon change that shows listening for voice input. Also using Google Assistant or voice input key in keyboard (google keyboard) the response time is limited to 4 to 5 seconds, meaning it would actually cut me off while i was still talking in Google Assistant and using keyboard voice input in Android Messages would only pick up first 4-5 seconds. I would pause for it to catch up at which point the voice input would time out/stop listening and never catch up. If it did catch up it would leave out whole sections of text. And what it was recording eas not always accurate. Cannot pinpoint when but seems going back to May or early June these issues started.
    I purchased a 1st Gen Pixel to see if it is a Android issue or OP and had no issues on Pixel with the above described issues. The OP5T is definitely a more premium phone, just shows the 2 year gap of development. But Pixel was very functional.
    I did do a reset of OP5T before doing the upgrade and set up phone from backup. Considering wiping again and setting up as new device, but really don't want the hastle of setting up a phone for 3rd time in 2 weeks.
    Also Android Auto does not seem to be affected by current OK Google issue, however it did still exhibit the "time out" of 4-5 seconds after trying to give message for text sending.
    #39
  20. G_Bryce_Lim_eNkJ
    Cupcake Aug 6, 2018
