cant install SuperSu and Twrp :( help
Thread Status:
Not open for further replies.
  1. NeverSettle
    Gingerbread May 18, 2015
  2. CM12BACON
    Ice Cream Sandwich May 18, 2015
    CM12BACON , May 18, 2015 :
    Im guessing you didnt unlock your bootlader? Thats the first thing you have to do, it will wipe your device!
  3. CM12BACON
  4. iDarkKnight
  5. rez1_k
    rez1_k , May 18, 2015 :
    What the hell, man? Why are you making double threads?!! Have you learned nothing from all the conversations about spam and redundancy on the forums? We were actually trying to help you in the other thread you started not more than 30 mins ago. :mad:
    https://forums.oneplus.net/threads/any-genious-out-there.311333/#post-11282898
    Pick a thread, stick to it. Ask a moderator to remove the other one. If you break forum rules, no one will be inclined to helping you.
    LifelessLewis, PRK.R, Kaaylim and 2 others like this.
  6. Alturki
  7. redleema
    KitKat May 18, 2015
    redleema , May 18, 2015 :
    He's already said he's seen it.
  8. Adikovec
    Honeycomb May 18, 2015
  9. prkharg
    Cupcake May 18, 2015
  10. Jeffreyvdv3lde
    Jelly Bean May 18, 2015
    TeamValor91 and rez1_k like this.
  11. Kaaylim
    CM12BACON likes this.
  12. redleema
    KitKat May 18, 2015
    DUDE! From your attached pic, its quite obvious you don't know what the hell you're doing. You need to do some reading and follow instructions carefully and IN ORDER otherwise you can get into a right mess.
  13. CM12BACON
    LifelessLewis, tandu and Kaaylim like this.
  14. rez1_k
    This guy doesn't seem interested in listening to anyone's advice - I sense a brick coming on...
    LifelessLewis and CM12BACON like this.
  15. redleema
    KitKat May 18, 2015
    he'd better start the RMA process now then. :D
  16. CM12BACON
    This. In this particullary order.
  17. PagalMunda
    Froyo May 18, 2015
    PagalMunda , May 18, 2015 :
    Just flash the recovery.img in fastboot mode. After flashing stay in fastboot and unplug your usb cable. Then use power+volume down button. This should work.
  18. rikardo1979
    Community Veteran May 18, 2015
    rikardo1979 , May 18, 2015 :
    redundant thread closed
    Please utilize your search function as there are plenty of threads with How to guides.
    Also I highly advise you to learn what you do and how procedures works before you start!
    Keep in mind that if you damage your device with bad flash these kind of things are not covered by warranty!
    redleema likes this.
