I1638970254169 , via OnePlus 8T , Dec 31, 2021 : Just bought the OnePlus buds z2 for my OnePlus 8T but it doesn't look like I can modify the functions of each bud i.e. double tap for another function etc. I also don't see the wear test screen advertised on the website. Is there something I'm missing?
Ajin_Grace_Thomas , via OnePlus 8 , Jan 2, 2022 : Is the auto connect also there because for me when I open the case it doesn't connect like the other buds do
I1638970254169 , via OnePlus 8T , Jan 2, 2022 : The auto connect works for me. Are you experiencing the same issues as me?
caelean , Jan 19, 2022 : Download/Update the OnePlus buds app on the playstore. You cannot use hey melody with OnePlus and oppo. Once the app is updated, you should be able to see the customise and ANC options. Hope this helps.
Ashwathmanickam , via OnePlus 7 , Jan 20, 2022 : What about the Dolby Atmos option? I have OP7 and I updated the OnePlus buds from playstore,still not able to find the Atmos option
Ashwathmanickam , via OnePlus 7 , Jan 22, 2022 : But it not like i have seen in OnePlus 9 model.They mentioned that Dolby Atmos and custom EQ option would appear in Bluetooth section
AaryaJain , via OnePlus 9R Carbon Black , Jan 22, 2022 : Could you send a screenshot of what is there under sounds and vibration, and Bluetooth too? Also try updating the OnePlus Buds app from Playstore. I don't have a OnePlus 7, i don't know about how the settings are diff
Ashwathmanickam , via OnePlus 7 , Jan 22, 2022 : I have updated that app and even contacted OnePlus support team.They said Dolby Atmos setting would appear in Bluetooth section.waiting for the solution from them
AaryaJain , via OnePlus 9R Carbon Black , Jan 22, 2022 : Maybe that phone is running os 12 since it looks like 9pro. I have 9R running os11 Do you have a Dolby Atmos setting under sounds? I do, and when i connect the buds, i get more options there including the EQ
Ashwathmanickam , via OnePlus 7 , Jan 22, 2022 : You maybe right bro. Ofcourse mine also running on OS 11.
AaryaJain , via OnePlus 9R Carbon Black , Jan 22, 2022 : YES it's that ! When you connect your earbuds, the earphone adjustment tile will become active and when you press that you'll get three styles and 'none', and the EQ.
Ashwathmanickam , via OnePlus 7 , Jan 22, 2022 : Actually I knew about that,but i want that like in OP9 pro.Soon maybe👍😂
