cant see network speed and battery percentage at the same time in oneplus 6t
  1. Ashish_Cheriyath
    Cupcake Nov 8, 2018
  2. jayanyway
    US Brand Ambassador Nov 8, 2018
    jayanyway , Nov 8, 2018 :
    Most likely a limitation on the screen but wondering if they can shift the network speed to the other side of the notch.
    Ashish_Cheriyath likes this.
  3. Ashish_Cheriyath
    Cupcake Nov 8, 2018
    Ashish_Cheriyath , Nov 8, 2018 :
    yep that wud be cool
  4. jayanyway
  5. rahulbhosale
    Gingerbread Nov 8, 2018
    rahulbhosale , Nov 8, 2018 :
    You can see both battery percentage and network speed by hiding battery icon as shown in the attached screenshot.
    Ben.Qin and Budruel like this.
  6. Ashish_Cheriyath
    Cupcake Nov 9, 2018
  7. Neddard
    Lollipop Nov 9, 2018
    Neddard , Nov 9, 2018 :
    Try setting the Font size slider to Small under Setting > Display.
    Works on my 6T, but you might not like all text being smaller.
  8. Ashish_Cheriyath
    Cupcake Nov 9, 2018
    Ashish_Cheriyath , Nov 9, 2018 :
    seems to work but as you said font being so small dosent look good
  9. rahulbhosale
    Gingerbread Nov 9, 2018
    rahulbhosale , Nov 9, 2018 :
    Now i have unhide the battery icon. Even now i can see both network speed and battery percentage. Also the display size and font size both are default (not small).
    See the attached screenshot.
  10. Ashish_Cheriyath
    Cupcake Nov 9, 2018
    i think its cuz you are using single ,im using dual sim nd im unable to see
  11. rahulbhosale
