9
can't turn volume down until just vibrator
  1. derbademeister
    Donut Feb 7, 2017
    derbademeister , Feb 7, 2017 :
    any statement of OP would be nice because this is really annoying to go to settings and change slider behavior all the time.
    #41
  2. ghostofcain
    Marshmallow Feb 7, 2017
    ghostofcain , Feb 7, 2017 :
    It is, you might not like it but it is default setting now
    No it's intended behaviour not a bug.
    Yes we can.
    Roll back then there are threads telling you how in this very forum..
    Slider to the top and enable vibration in alert slider settings.
    Follow the instructions in one of the roll back threads.
    Same fix as the others, slider to top, enable vibration in settings.
    What, Follow instructions?
    You might not I do, it fits my usage just fine.
    Yes it's intended behaviour, some have reported that live help have said it might be "fixed" in a future update but I'd take that with a pinch of salt.
    #42
    Sun90 likes this.
  3. stin00
    Gingerbread Mar 16, 2017
    stin00 , Mar 16, 2017 :
    Any news on this? Im still at 3.2.8 and waiting for this to be reverted in 4.X.X versions :)
    #43
  4. harrry learmonth
    Eclair Mar 16, 2017
    #44
    stin00 likes this.
  5. jtodd98
    Froyo Mar 16, 2017
    #45
  6. Maxidou
    Cupcake Sep 25, 2017
    Maxidou , Sep 25, 2017 :
    I have the same problem and I think I can decide to go back to Samsung because of this...
    #46
  7. AdeRickus
    Cupcake Jun 22, 2018
    AdeRickus , Jun 22, 2018 :
    I'm in a position you guys aren't. It's 4am here and I've only just received my shiny 256gb, 8gb one plus 6. However, I use a software volume method and the phone has woken me up. I use the method at work, the doctors, the cinema. The reason I don't buy Apple, is because with Android I can automate this. So, this is being boxed up and sent back at 8am. Utter rubbish and I'll never come back.
    #47
  8. SiddharthPatil
    Honeycomb Jun 22, 2018
    SiddharthPatil , Jun 22, 2018 :
    did you see that liitle setting menu below volume levels. press on that and wooohhh you can see vibration label
    #48
  9. AdeRickus
    I don't think you understand, I have a program that does this automatically, I shouldn't have to do ANYTHING. Your sarcasm simply degrades your status. Sorry, but this is wrong
    #49
  10. GopalB.
    Nougat Jun 22, 2018
    GopalB. , Jun 22, 2018 :
    So you are giving back your OnePlus 6 right!!!
    Bye...
    #50
  11. ghostofcain
    Marshmallow Jun 22, 2018
    ghostofcain , Jun 22, 2018 :
    Since you can't even manage to post in the correct forum, his thread is for OP3(T), I suspect user error.
    #51
  12. AdeRickus
    #52
  13. ghostofcain
    For the OP3(T), why not tag it onto an OP6 thread.
    #53
  14. AdeRickus
    I'm sending it back to be honest, not really any point on the forum
    although, I have posted on similar threads elsewhere, where people are complaining about the volume not allowing a software controlled silence
    my annoyance is now being redirected at tech support as they also are at a loss to explain the reasons behind this decision, which for me makes the device unusable
    don't worry chap [e]1f609[/e][e]1f44d[/e]
    #54
