Car connection via OnePlus 7 Pro
  1. Reub
    Froyo Jul 2, 2020
    Reub , via OnePlus 7 Pro , Jul 2, 2020 :
    Your software updates are messing with my life man! I was able to use the vehicle voice function via Bluetooth phone connection to make phone calls. When I use it now, it goes automatically to navigation.
  2. Caomhin
    Lollipop Jul 2, 2020
    Caomhin , via OnePlus 6T , Jul 2, 2020 :
    Unpair everything from the phone, then reset your Bluetooth adapter.
    Settings, System, Reset Options, Reset WiFi Mobile Bluetooth.
    Restart the phone.
    Then reset the Bluetooth on all devices you wish to connect. Check each device manual on how to reset its Bluetooth.
    Then pair them back up again
    See if that helps
    Bouncer71 likes this.
